Say I pumped up a tyre to a set pressure ie 18 psi and got a length of hose attached to an old say foot pump connector and the other end to the mbc, wind the mbc right up, connect the hose to the tyre, then unwind the mbc until it starts to let air out, do you think this would be accurate, ie set at 18 psi, iam talking about the ball and spring type mbc not bleed valves
