Hey guys
Right some of you might know i'm going to wobblys on saturday for bbq and the brakes have been giving me issues fora while now
This is what has been done
New front discs/pads
offical volvo
Rear discs and pads
Mintex ones
Now brakes were still soft after bleeding so i and when come off pedal that rear right brake pad moving about
Into garage and my volvo guy tells me who i have used for 5 years that the pad is moving up and down in rear right calipier, it has seem to have corroded a bit and he reckons if i replace with volvo ones might hold better
He says this is not causing the piston to travek more and it is not loose side to side.
He clamped the front ones off to check the pedal and the pedal was better with it clamped off.
there is still some movement in front calipers when not moving, i know there has to be some or it would seize up all the time but still too much he reckons.
He didn't give me answer in how to fix as he looked at brakes for free for me when replacing a drop link.
So the pedal is soft, though safe mind, he says he thinks is just the same as his v70
though he has 2.4 petrol with 280mm brakes, i have a t5 with 301 i think it is.
The brakes have always been good on the car and im not 100% happy with them, especially since i got like 10 hour round trip to drive in 5 odd days time.
anyone got any suggestions off hand, replace fluid, might of over boiled???, was changed about 2 years ago, new pipes ???
I just don't want to go down the route of doing things and it the same, the pedal has always been good and i assumed was because back brakes needed done, then i changed front and ahhhhh I'm stressed about it lol
Please help, anyone at the BBQ on Saturday will be able to see what i mean, unless there is something so obvious
Cheers guys
