does any 1 have any pics of the air con removed , and whats the best easyest way to do , i want to remover the air con rad so i can use a thicker intercooler etc and think it will help with a bit weight loss.
cheers
cheers
Just buy yourself a belt off a none aircon car and then remove the pump/aircon rad etc...... Simples....Wonder if the aircon rad off an 850 is the same as a 960?, I need one for mine,lol.
Previous cars:
Lol.....
Previous cars:
Hi,
you can keep the air-con and still have a thicker intercooler if you want. It's a bit harder maybe, with some modification and fabrication but that's what I'm running.
There's a thread with some pics here:
http://www.volvoforums.org.uk/showthread.php?t=65061
HTH, Pete
'97MY black 855R manual M56H
Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
No probs mate, just got to find out now....
Previous cars:
leet5r (Sunday 4th July 2010)
Funny isn't it, I'm trying to put aircon back into my 855 after it was butchered with bolt croppers to fit a bigger intercooler. Borrow the aircon pipe removal tools from your local dealer, the blue and black ones are the ones you need. They fit on the hard pipes and when you pull them back into the quick release fittings they expand the circular springs that hold the fittings together. You can then put everything back in if you ever want aircon back. Remember there is no need to loose your aircon, with a bit of playing you can keep it with a bigger IC. You should get the system de-gassed before disconnecting anything.
HTH Andy
it doesnt work like , wether it needs re gassing or what., am after a big big intercooler when funds allow and also the volvo RIP kit
