Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    mightywolf's Avatar
    Jul 2009
    Bradford, west yorkshire
    166
    Intermittent starting problem
    My '98 S70R has got a funny little habit. It only happens occasionally (maybe once twice a week at most). I'll get in, turn the key and it turns the starter motor but won't fire. If I turn the ignition back off and on it usually fires up straight away (I sometimes have to turn it off and on 2 or 3 times). I've started to notice it happens more if I've parked on a hill. It happens regardless of the amount of fuel in the tank. The rest of the time it fires up first turn straight away.
    I've also noticed it occasionally does it sat in traffic. It'll idle normally and suddenly the revs will drop like its about to stall and then return to normal (it never stalls) Its an auto an it does this regardless of the gear and happens in neutral or park so I don't think its a gearbox thing.
    Any ideas before I have to go down the route of changing all the plugs, leads etc etc?
    cheers guys.
    the wait is nearly over
    polak t5r's Avatar
    Mar 2009
    cornwall
    26
    hi mighty wolf i had the same problem on a 850 t5 few years back every time the car was on a hill it wouldnt start changed everything it turned out to be maff sensor proberly not the same thing but if you try everything else might be worth a look
  3. The Following User Says Thank You to polak t5r For This Useful Post:
    mightywolf (Friday 18th June 2010)
  4. #3
    Phuturephantasy's Avatar
    Apr 2005
    Somerset
    7
    First thing I would try would be cleaning the Idle air control valve and the MAF sensor - a search should bring up any how to's
  5. The Following User Says Thank You to Phuturephantasy For This Useful Post:
  6. #4
    mightywolf's Avatar
    Jul 2009
    166
    cheers guys
  7. #5
    538 Nm on the old car. Now
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    Had a similar starting problem with our 99 V70 2.5D.
    Would crank until the cows come home but would not fire up.
    When it happens again try taking the key out, turning it over and then starting.
    If it fires up I would suggest that it is the ignition ring antenna.
    This is the bit around the place where the key goes in with White marks on.
    I am told it reads the key an turns off the imobiliser.
    Regards
    Steve
  8. The Following User Says Thank You to Blackdog For This Useful Post:
    mightywolf (Saturday 19th June 2010)
  9. #6
    eVolvolution
    Dacvolvo's Avatar
    Sep 2004
    Around Glasgow Car: Volvo S60 D5
    14
    I also had a similar experience. Turned out it was the fuel filter under the car - a stone had managed to pierce it and if I left the car parked up for more than 2 hours, I would have to turn the key twice before she would start...
    The first turn of the key and the starter motor would just turn but the engine wouldn't start. I would wait 3 seconds and then turn the key again and the engine would roar into life.
    Parking on a hill facing down the way would cause the problem to be more frequent. Also, there was a very (and I mean very) faint smell of petrol.
    It cost £10 to have a new fuel filter installed from the local Volvo garage.
  10. The Following User Says Thank You to Dacvolvo For This Useful Post:
  11. #7
    mightywolf's Avatar
    Jul 2009
    166
    I've only just replaced the fuel filter, so its not that. It does fire up if I turn off the ignition and turn it on again. Sometimes have to do it 3 or 4 times but it usually fires on the 2nd turn. I'm gonna clean the maf and the idle air valve first
  12. #8
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Crank and cam sensors would also give you problem mate, get the codes read if you can saves a lot of messing around.
  13. The Following User Says Thank You to Jamest5r For This Useful Post:
    mightywolf (Wednesday 7th July 2010)
  14. #9
    mightywolf's Avatar
    Jul 2009
    166
    had the codes read and it hasn't got any coming up. i've cleaned the m.a.f but that hasn't made any difference. so where exactly is the idle air control valve?
  15. #10
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    Mightywolf,
    I still go back to the Ignition Ring Antenna.
    As I said same symptoms. Would crank, not fire but would eventually start on some time second, sometimes third, and sometimes even more. Would even start first time some of the time LOL!
    Fortunatally the V70 came with more history than the Victoria & Albert museum.
    This showed that the problem was not new to the car and had indeed been back to Volvo for diagnostics which were inconclusive. She left the dealer not cured but with a note of suspected faulty Ingition Ring Antenna.
    We changed the part (circa 40 quid) and the car has started first time, every time ever since.
    Best of luck tracing the problem.
    Steve
  16. The Following User Says Thank You to Blackdog For This Useful Post:
  17. #11
    mightywolf's Avatar
    Jul 2009
    166
    cheers blackdog, but i don't think its that. it stutters sometimes while sat at the lights or when you put your foot down (only for a second and then it acts like nothings wrong)
    the idle air control valve looks fine but i'm gonna give it a quick clean anyway. think it might be plugs or leads.
  18. #12
    mightywolf's Avatar
    Jul 2009
    166
    ok quick bump. still have the problem. I've changed the plugs, leads, dizzy cap and rotor arm. Cleaned the maf sensor and the idle air control valve. its not throwing up any fault codes either.
    It seems to be fine for a while then it comes back. for a couple of days it'll do the not wanting to start thing and then it won't come back for a week! But it does the rev drop thing nearly every day. Sat in trafic and it just occasionally gets a slight drop in revs like its gonna stall and then picks up again. Also noticable is when your stood and you set off again I get a blip like it hesitates and then clears and is fine. It only does this at very low revs (i.e when setting off from lights or pulling out of a junction which is a bit annoying).
    I am still thinking it could possibly be the idle air control valve just sticking? I did give it a real good clean though and it seemed fine. Any more ideas?
    Bailey dump valve + Boost gauge + Manual boost controller + K&N induction kit + Powerflow cat back exhaust + Strut Brace + Bilstein shock n sports springs with 40mm drop
    = very fast and still turns corners
  19. #13
    mightywolf's Avatar
    Jul 2009
    166
    anyone?
  20. #14
    JelT5's Avatar
    Feb 2009
    1,925
    Wish I could offer some advice that might be useful, it looks like you've pretty much covered everything though.
    Could it possibly be a vac leak on the BOV?
  21. The Following User Says Thank You to JelT5 For This Useful Post:
    mightywolf (Wednesday 6th October 2010)
  22. #15
    mightywolf's Avatar
    Jul 2009
    166
    Quote Originally Posted by JelT5 View Post
    its funny you should mention that. I did suspect my bov may be leaking at the diaphram. Could that cause it? its a bailey dv26.
  23. #16
    JelT5's Avatar
    Feb 2009
    1,925
    Quote Originally Posted by mightywolf View Post
    It's a possibility- BOVs can cause some problems on T5s. My Forge one didn't, I took it out because I wanted to hear the turbo chatter lol.
    For the sake of a few minutes work- why not remove the DV, block the hole up and try it? You never know.
  24. The Following User Says Thank You to JelT5 For This Useful Post:
  25. #17
    mightywolf's Avatar
    Jul 2009
    166
    it won't do any damage will it? obviously the re-circ is blanked off, but won't it do any harm if it can't dump the excess gas?
  26. #18
    JelT5's Avatar
    Feb 2009
    1,925
    No it won't mate- we don't run enough psi/bar of boost to cause damage to the turbo.
  27. The Following User Says Thank You to JelT5 For This Useful Post:
  28. #19
    mightywolf's Avatar
    Jul 2009
    166
    cool i'll try that. cheers.
  29. #20
    Junior Member
    eddielam's Avatar
    Aug 2009
    0
    try the fuel pump relay, mine does the same, a friends was cured by it, i will change mine tomorrow and write back. cheers
  30. The Following User Says Thank You to eddielam For This Useful Post:
    mightywolf (Friday 8th October 2010)
