Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    More cars than a Showroom
    volvokid's Avatar
    Jul 2008
    Cruden Bay (Scotland)
    1,464
    Quote Originally Posted by t5_monkey View Post
    256 all the way - can definitely tell the difference on dyna-audio - go 384 if you can
    Do the S40's have the dyna-audio subs in the boot as well like the C70?
    Martyn
  2. #22
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Quote Originally Posted by volvokid View Post
    I've found music that is ripped at a lower level sounds crap on a stereo with surround all the sound that comes out the back speakers just warbles and sounds stuppid.
    I find that when it drops below 160, that it can sound "tinny" even through normal headphones.
  3. The Following User Says Thank You to LiamT4 For This Useful Post:
    Storm-Troll (Sunday 13th June 2010)
  4. #23
    Storm-Troll's Avatar
    Oct 2006
    In The Country
    1,025
    i use a program called cook edit pro which is a pro audio editing program. i mix all my stuff on there and splice etc etc so ill bump up the bitrate to max and see how it changes
  5. #24
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    You could go to 320, which is the normal max. Depending on how good the software/hardware is it is possible to go to over 600. You have to remember though that even at 320 its still not at cd quality, which is uncompressed. Try 320, but remember at this level you'll be not far off halving your storage capacity from what you are currently using (196).
    Btw, i'm not an expert in this. I'v known about mp3 bit rates and that standard mp3 sound quality isn't the best and also known a bit about sound systems, but i'v been reading a bit more into this in the last couple of weeks since i noticed that a cd that i had bought had a funny symbol on it that said super-audio underneath it and wanted to know what it meant, which has lead me to learn a bit more about other things. Some of which is quite interesting. lol
  6. #25
    850 2.5 10v's Avatar
    Jul 2008
    186
    You guys need to spend more time looking at the road than a bit of album artwork the size of a matchbox.
    Pointless IMO!
    Volvo 855 2.5 10v CD
    Its got everything except a turbo - boo hoo...
  7. #26
    Oct 2006
    In The Country
    1,025
    Quote Originally Posted by 850 2.5 10v View Post
    Pointless IMO!
    lol but the roads are boring... tarmac and white lines. seen one u seen em all .. lmao..
  8. #27
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    isn't the Volvo system a different Ohm setting on the speakers, ie, 8ohms where normal is 4ohms? Does this not impact when using non oe headunits?
    (sorry, slightly off topic).
  9. #28
    Oct 2006
    In The Country
    1,025
    Quote Originally Posted by LeeT5 View Post
    I couldnt comment on the technical side of that question matey as I dont know. but all I can say is the OEM stereo was good but the sound from the Alpine is even better so Im guessing that everything is ok or it would sound pants.....
  10. #29
    "The Instigator"
    The Flying Moose's Avatar
    Sep 2008
    Norwich, Norfolk
    2,842
    Without going into the technicalities ill explain. If the volvo stereo system runs 8ohm speakers then the amplifier as it is optimised for the car will run at maximum volume when connected to 8 ohm speakers. If for instance the Volvo speakers are a combined 200W RMS and you had a stereo that runs is quoted to achieve 200W at 4 ohms then the stereo would not be able to produce 200w at 8 Ohms it would typically produce 100W. The figures vary dramatically but an 8 ohm speaker at 200w will normally require a 400W 4 Ohm amplifier (typically double the 8 ohm reading) to run at maximum volume. This is where its important as if these factors are not accounted for then you can either overwork your speakers or overwork your amplifier. If however you do drive around with a mini glastonbury in you car then your pretty safe in most scenarious.
    Any more audio related questions/quieries like this fire away, apparently I was once a professional sound engineer...
    Arguing is pointless....she may not be right but she's never wrong
    Tell her a remap is just having your satnav updated.....
  11. The Following 2 Users Say Thank You to The Flying Moose For This Useful Post:
    LiamT4 (Thursday 24th June 2010),Storm-Troll (Thursday 24th June 2010)
  12. #30
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    Thanks for this info, I think V70ETS.
    ST, might I ask, if it has not already been mentioned, as to why did you not go down the usa spec/imiv units so you can use your ipod?
    Did your car come with the HU803 and the dolby pro logic system?
    Actually whilst we are talking about HU, who makes the HU803/HU850?
    Darren
  13. #31
    Oct 2006
    In The Country
    1,025
    Quote Originally Posted by Libra View Post
    dont understand ya question mate. I AM using my iPod on it. its USB conected to the Alpine......
  14. #32
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    If you wanted to use your ipod to play through the cars OE HU8**, then why did you not just buy a usa spec or iMiv module instead of forking out for a new Alpine HU with ipod connectivity?
    Darren
  15. #33
    Oct 2006
    In The Country
    1,025
    Because I Wanted the Alpine Headunit. and you cant get Pandora Internet Radio On the Volvo Stereo Like U can On the Alpine Unit. So It was a No brainer really, plus I hate the standard Boring looking Volvo Head unit. lol
  16. #34
    spencem875's Avatar
    Aug 2005
    Stanmore, Middx
    16
    ST can you reload those pics so i can see what your unit looks like in the new surround. please
    03' S60 R
    96' 850 T5 (gone but not forgotten)
  17. #35
    Oct 2006
    In The Country
    1,025
    Quote Originally Posted by spencem875 View Post
    I will take some pics tomorrow mate and post them up.. seem to have lost my old ones... Im just fitting the hew holder at the moment for my new iphone 4 so Ill take some piccys tomorrow.
