I have tried search (to no avail), but i wondered if anyone knew of an exact or correct location template for the badges that adorn the rear tailgates of V70's?
Any ideas?
Any ideas?
Well.....
P2's (2000-2004) had the VOLVO to the left & the V70 bit (with engine badge below) to the right. The exception being the R which had V70R & AWD below.
P2's (2004-2008) had the VOLVO to the centre in the small gap between the window & the grip bar. V70 to the left & the engine to the right. (same again but the R had the whole V70R to the left & the AWD below).
Mix it up a bit! Try moving them about on blu-tac or something & see how it would look.
The Volvo in the middle where it's V O L V O must be avoided as it looks very sad.... almost scraping Barry teritory. Just don't!
I have had the volvo on the left & now in the centre, which I think looks better. Also leaves the option for some personalisation on the right. (I have a swedish flag)
You think I know **** nothing! But let me tell you I know **** all!
I want a Metal Moose next to the Volvo Script on the left of the tailgate and one on each wing.
"Sgt. Butterman? Little hand says it's time to rock'n'roll!"
"Bring the noise!"
Be warned J, I had the metal "volvo R racing" badges on the wings & they rusted.
My advice is to coat the edges with clear varnish or similar coatings to the edges before fitting them. Cheap crome & bad coatings.... disaster!
Has this happened with the metal badges we saw a few weeks ago?
"Bring the noise!"
Hi
Hope this may help
Rob
LeeT5 (Thursday 3rd June 2010),princepugh (Friday 28th May 2010)
Yes J, the small paralelogram ones with the R on them in red & black or blue & yellow.
Be warned!
I looked into getting viking in the same font instead of volvo across the back of my xc but the only place i could find that would make them wanted £25 a letter and i didnt want them that badly
Get an E and an R made by them & put LOVER on the tailgate! That would confuse the local chavs.
Or a U and an A..... I'm not giving any hints on this one.
So for £50 you could have (keeping the V at the start..) valor, valve, viola, viols, vocal, vodou, voila, voile, volar, voled, voles, volta, volte, volti, volts, volva, vowel, vroom, vulgo and vulva....
VROOM in the volvo letters might be a laugh, but may be missed by most folk.
