jcviggen uses a gt28 and has made 420 bhp iirc so they not bad , tim and elliot both use a gt3071. both good turbos
If I buy a Garrett: http://cgi.ebay.co.u...=item1e5a54d10c
Should I order it with the K24 housing? I take it will then let me bolt it to my ported manifold without using an adaptor?
Slight change of plan, turns out my bores are worn to the tune of 11 thou that explains the oil burning, and my forged pistons are 0.5 oversized, so it would have needed a rebore anyway
Has anybody changed their main bearings? What a weird setup, it depends on what letter is stamped on the block and crank, then you refer to a table, it tells you what bearing to put in, you can end up with one thick and one medium bearing on the same jornal.
Odd setup
Got the block back today Rebored 0.5 plus 4thou for clearance and all my gaskets turned up to, you really don't want to know the cost!
The block is being cleaned again, then painted.
Should have the bottom end rebuilt tomorrow, and collecting the head from the machine shop.
I really must get the pictures off the builder phone!
On the under piston oil squirters, there's a valve, looks like a small hydraulic tappit, which way around does it go? I can't remember!
Pistons are back in Hopefully we will finish the bottom end off tomorrow
sounding good paul any pics
There are Pete, the engine builder has been taking them, but he hasn't sent them over to me!
The head is back on, bottom end is finished, just waiting for a few more gaskets, then on to the next piece of fun, the manifolds
Just been reading this: http://volvospeed.com/vs_forum/index...page__hl__*na*
Apart from re-drilling a vacuum conection, it should work, and the N/A throttle bodies are 3" looking at it too, the tps sensor is in the same place, and for the connecting hose: http://snabb.3dcartstores.com/NA-Thr...SV70_p_37.html
It may be easier to make a new lower IC to TB pipe with IACV takeoff if your going RIP Paul. That way you can use just a 45 degree bend off the TB and they are much cheaper everywhere than one of those TB hoses with the IACV takeoff already in them.
Nothing too exciting today, ordered my diff and IPD anti-roll bars
Are the 2.0 and 2.5 throttle bodies the same size? I'm gonna get a complete manifold anyway, but can only find 2.0 ones.
Its coming along nicely by the sound of it Paul, keep up the good work.
Thanks Alan It's getting there slowly
Do you think you be at HLM with it, or is that a silly question?
anywho sounds like shes going to go well!
