Got a M56H from a t5 if your interested.
Which side? I need the drivers side, the longer one
Got a whole car mate any side you want, £20 + p&p
Sent you a PM
I've read a few threads now, what are people's views/thoughts on getting a LSD diff? I rang Quaife today, they want £700 delivered
The car will have about 300whp, I'm thinking I might need something to help tame it.
The cheaper option is a M59 box if you can find one, i payed £200 with drive shafts it dyno'ed 269whp/456nm with a 16t, now have an 18t so hopefully a bit more power and the box seems fine but as always this is just my own experice's, but im not gentle with it either on the 1/4mile
I thought the M59 was a weaker 'box? But, then, how weak is it?
1.4bar that's 20psi, about what I'm going to be running..................... ok, who has a M59 'box and shafts?
Salvo is always worth a go.
Been up the garage again today, the engine is out, and the head is off
All 5 pistons are coated in oily carbon, its been burning something it shouldn't, next job is to strip the bottom end.
Also, what's the problem with the new from Volvo oil pumps?
Todays update, the engine is completely stripped, bores are all ok, hopefully it will get away with a glaze bust
Crank is good, with just a slight scuffing on the shells, going to put a new set it, from Volvo £170
One other question, are the main bearing bolts, the ones that go through the ladder frame, stretch bolts?
I need some advice:
How much boost can a K24 produce? (maximum)
What actuator does it use? and can it be uprated?
How much boost pressure can a stock head gasket take?
I'm building my engine with H rods, forged pistons, ported head and piper cams, 3" intercooler, siemens injectors and TT ECU.
Is this a good setup? I can't afford to go for a Garrett just yet (Unless anybody has a spare good one )
Hey paul the standard head garskets are pretty good im sure russ and tim williams are using the standard ones.
As for the k24 it might be best to ask rnash or who ever else runs one im sure some one asked this a while ago and if i remember correctly it was s70 chris that gave the answer.
It deffinatly sounds a very good set up and should provide lots of power who are you having to tune your tt
Or, is this the way to go? They are cheaper than I thought
http://cgi.ebay.co.uk/Garrett-Turbo-...item1e5a54d10c
Personally if your spending that sort of money go for the gt30 http://cgi.ebay.co.uk/Garrett-Turbo-...item1e5e77f270
Also who is tuning your turbo tuner???
I didn't see that one, thanks Pete
Its being tuned by the engine builder, he normally works on Mitsubishi Evo's, he is ex prodrive WRC mechanic too.
The website is cr*p http://wbmotors.co.uk/
