How do you guys usually set them up?
Its a 98 PreME7 2.3 T5.
Is it just the usual half a hole business? Or can I pipe up a pump to see what values it should be at?
Ta!!
Ta!!
best way is to pipe a pump up i carnt remember the correct psi but im sure its around 3-4 psi
What happens does the arm suddenly blow out?
You might find the video in this page helpful:-
http://www.ipdusa.com/product.asp?st...hStartRecord=1
Think it mentions calibrating to base boost mid-way through?
Princepugh
V70 T5 P2
pigfight (Thursday 8th April 2010)
Ah cheers,
I cured my boost spiking by adjusting the actuator, now it wont boost as high as it did before!
Hmph. Is only around 2-3psi less, but the MBC doesnt seem to be doing anything.
Cheers that vid helped loads. Set it up with a gauge I made, its ****ing awesome now, doesnt spike at all and is a shed load better.
Ta!
