Page 8 of 8 FirstFirst ... 678
Results 141 to 155 of 155
  1. #141
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Crazy_C View Post
    So that is now 10 speakers in the front of the car, going to install a similar panel in the rear doors with 2 of the same speakers in each door. And then I will be changing the install in the trunk so I will be running four 15" JBL subs
    i used to run 3 x 15"s in BT, what amp you using to run them?
  2. #142
    Feb 2010
    47
    Nice set up there, the boxes look rather small though or did they literally take up your entire trunk space?
    I'll probably see about running the subs off a JBL 1400.1 amp, and then a JBL 1004E amp for the speakers.
    Looks like the plan may change though, cos I was looking to run 4x 15" GTO series JBL subs, but will probably run 4x 12" Power series JBL subs now, which despite being smaller, are hella lot more powerful!
    matt black turbo brick rat - you know it makes sense
  3. #143
    p fandango's Avatar
    Aug 2004
    4,216
    the boxes were originally made for the QXF (Maystar) subs but as i like sticking with one manufacture thoughout changed them for Vibes, the Maystars did sound better tho. They were very deep
    couldn't find any specs for the amps, but assume its 1400watt (RMS?) Mono channel. What ohmage is it stable to?
    i do like 12"s myself (the S60's going get 2 eventually), had a lovely Kenwood install with 2 x 12"s but ran too much power & split both cones lol
  4. #144
    Feb 2010
    47
    The amp is actually 1500W RMS at 2ohm, or 1200W RMS at 4ohm. It is just 2ohm stable, not 1ohm, but that doesn't bother me. It's a bloody good amp actually!!
    The amp is also known as the 14001E amp, but most people call it the 1400.1 so may be why you can't find spec on it.
    That is a very nice install you got there. I'll be running the subs in maxiumum size ported boxes, for maximum SPL More fun that way hehe
  5. The Following User Says Thank You to Crazy_C For This Useful Post:
    p fandango (Saturday 12th June 2010)
  6. #145
    p fandango's Avatar
    Aug 2004
    4,216
    working in carpentry for so long i got bored with the same install very easily, so it got ripped out & started again. Thanks for the comments
    i could never get on with ported boxs, was never happy with the sound so always stuck to sealed
    even running 4ohm should be good enough
  7. #146
    Feb 2010
    47
    Ahhh, fair enough then, being in carpentry. Know the feeling about being bored with looking at stuff anyways, let alone with that aspect of things too lol
    Yea, gonna run dual 2ohm subs, more practical for transferring to other applications where 4 of them might not fit.
    Plus, I think running them at 1200W will be loud enough with those subs, though I may decide to only run 3 of them, and have them running at 1.3ohms (provided the amp will cope) and have them seeing more power each
    Cos what I am thinking about doing, is running 3 subs, having the middle one higher up than the other two, have my fire extinguisher on the bottom in the middle, and then have some 6x9s above the subs on the sides, to give some nice sound coming out the tail gate
    Will see what happens
  8. #147
    Feb 2010
    47
    I got a parcel arrive for me today
  9. The Following 2 Users Say Thank You to Crazy_C For This Useful Post:
    JelT5 (Friday 18th June 2010),Turkish (Friday 18th June 2010)
  10. #148
    Junior Member
    ANDY B's Avatar
    Jul 2009
    3
    poor sheep that's what happens when you send them in the mail
  11. #149
    Feb 2010
    47
    Yea, I ordered a home made lamp chop kit a month ago, only arrived today, bloody Royal Mail
  12. #150
    Junior Member
    ANDY B's Avatar
    Jul 2009
    3
    he he
    looks good.
    fix it on with some big rusty nails and barbed wire
  13. #151
    Feb 2010
    47
    Hahaa, not a bad idea, might use some rusty bolts or something like that to hold it down
    And update time!! Car is back now, after the garage ballsed things up, and she's looking awesome
    The new metal panelled rear "window"
    And of course, the rat rack hammock WOOOOOOPP!!!!
  14. #152
    JelT5's Avatar
    Feb 2009
    1,925
    Brilliant! All of it- just genius; I love it
  15. #153
    850 2.5 10v's Avatar
    Jul 2008
    186
    Looks like a modern interpretation of a mad max baddie car.
    I like it.
    You guys really seem to know your stuff on sound systems, installs etc.. great skills all over this forum.
    Volvo 855 2.5 10v CD
    Its got everything except a turbo - boo hoo...
  16. #154
    dazat5's Avatar
    Aug 2006
    Cheltenham
    18
    lol what? gotta admit, it does look kinda hmmmm rustic?
  17. #155
    Feb 2010
    47
    Quote Originally Posted by JelT5 View Post
    Cheers dude Still got more to go on it too. Gonna do about a 4" suspension lift using spacers on the top of the struts and stick chunky all terrain tyres on it
    Quote Originally Posted by 850 2.5 10v View Post
    I like it.
    Cheers again mate Yea, it's being done as a sorta post apocalyptic rat wagon. So all matt black for stealth. The rusty hood as if it's had an engine fire Roof rack for supplies and hammock for camping at night quickly
    Quote Originally Posted by dazat5 View Post
    Hehee, yea, I get the "WHAT?" reaction quite a bit shockingly enough LOL Great fun though
