how do you change gear box oil on a s70r maual easy or hard and would it realy need doing at 95 k cheers
Impossible to say whether it needs doing unless you have owned the car from new and never bothered! If your not sure then always best to change anyway. It is easy mate. Just need to locate the drain plug and the filler plug. Make sure you drive the car for half hour too to warm up the oil otherwise it takes ages to drain.
ikp_77 (Monday 22nd March 2010)
