What kits are people using? im considering changing my standard R setup for aftermarket stuff?
im on koni adjustable with 40mm lower springs..............
Mine's on FK coilovers(Highsport)and about 45 mm lower as standerd.
get in,shut-up and hold on.
KISS Rs
850R manual, Rica 310, IKEA fitted bathroom, H&C running water, Jetex 2.5", pipe rack, cap stand, Forge BOV, circular wheels with full 360 degree rotation, 302mm discs, IPD front and rear anti-roll bars, numerous shiny features, sub-atomic particle accelerator, VTOL capability ...Volvo With Attitude!!!
Also to be seen in a gold Honda CR-V these days...
"It's really fast, and growls like a tiger!"
Lesjofors sport spring kit 40mm than standard....
Part number 4595811
Cheers Mark..........
EBC DRILLED GROOVED DISCS. EBC GREEN STUFF PADS. AIR CON REMOVED. TWIN EXIT EXHAUST. BLACK MESH GRILLE.GREEN PAPER AIR FILTER. FRONT SPLITTER. POLY TOP BUSH.V70 REAR LAMPS
The greatest trick the Devil ever pulled was convincing the world he didn't exist
http://www.r2rc.co.uk/landing/index.htm
Flatout Phil (Tuesday 9th March 2010)
Hi. These are what i went for on my 855
http://www.partsforvolvosonline.com/...oducts_id=3839
Perfect, easy DIY fit... improved handling and look 100%!
J5
It's a ROCKET PROPELLED ARMCHAIR, and I LOVE IT
Current mods :ZTRONS cd/dvd touchscreen headunit, Clear side repeaters, Zenon effect headlamp bulbs, Equus turbo boost guage, Front strut brace, R-SPEC MBC, NGK Iridium 10 plugs, 40mm lowered springs, Powerflow 3' stainless steel cat back exhaust ending in a 4' outwardly rolled tailpipe ("Volvo's....... Theyre boxy, but theyre good")
Ive got bilstien B4's, eibach springs 40mm, camber adjustment bolts, lower IPD rear anti roll bar and front strutbrace ....car handles lovely .
The 2 best items were the strut brace and the anti roll bar ...also got the suspension set up properly on a computerised 4 wheel alignment machine check here for a center close to youhttp://www.alignmycar.co.uk/
It makes so much difference getting it all set up correctly ...really transformed my car .
Rich
1996 855 R
1995 855 T5
1968 Califorian Imp
ANDY B (Sunday 14th March 2010)
I'm fitted the favourite setup of Koni FSD's and Eibach springs this weekend.
Ive just had the camber set up so I dont get abnormal wear ( I think its something like 0.50 degrees) ... but the bolts will alllow more camber adjustment ( something like 2.0 degree's ) when I take the car on track days ... make it turn in sharper . Although it turns in ok as it is at the moment
Then after the track day take it back and get the front camber reset . Its £15 per adjustment ... so not to expensive cheaper than new tyres ... I do a lot of motorway miles so not too keen on wearing the inside edges of my tyres.
Rich
1996 855 R
1995 855 T5
1968 Califorian Imp
t5 stealth (Tuesday 9th March 2010)
if you use a 40mm drop kit im guessing the R suspension is already dropped around 40mm over a standard t5? so will it sit the same height as with the original setup?
I believe the R was 20mm lower than the standard 850's so a 40mm drop will effectively give around a 20mm drop on an R
I thought the 850R had a 30 or 40mm drop over std. My 855R is riding about that at the moment anyway, and thats with std 850R suspension.
I've just bought some Eibach springs and will shortly be getting Bilstein B4s to go with them, along with the IPD ARBs when I can afford them - the 850R and T5-R had reasonable ARBs fitted as std so I'm going to see how it handles with the 850R ARBs before shelling out another £350 on the IPD ones.
Currently - '96 850R auto
Previously - '97 S70 T5 manual, '98 V70R AWD auto, '98 V70R Auto in Nautic Blue Mica with LPG (went to Germany!), 1996 850R Auto, lots of various 940s, 960s and a crappy 850 2.0
How much are your laser alignment people charging - my local place in Bexleyheath wants £160 which I think sounds like a RIP off even if it is on a Hunter system - or is this the going rate? Anyone else, I'm not talking get tracking done at Kwik Fit, this is a full camber, toe in, caster and thrust angle alignment.
KISS Rs
Hi Phil
The first time I paid about £70 quid mate.
Do a quick search and find one close to you and give them a call.
I went to a place in Tonbridge on saturday to get mine checked after I put the rear ARB on and they charged me £52 to check and adjust all 4 wheels.
You get a print out showing toe in camber thrust angle aalignment etc .... your place does seem expensive in my experience , unless there is something else they are doing ?
Give us a call if you want a chat about it
Rich
1996 855 R
1995 855 T5
1968 Califorian Imp
Flatout Phil (Tuesday 16th March 2010)
Guys
Not only is my car a bit of a shed, no offence Rob , but I'm kind of skint and can't justify spending hundreds on Koni FSD's or whatever. Can anyone recommend something cheap (like the Budgie) that will do the basic job?
Cheers
cheap way to get your car sorted:
Brand new OEM dampers, sports sprints, strut brace, Rear Roll Bar and alignment check.
That should be enough to keep you going on a budget.
BSR stage 3, BSR Stainless Exhaust, Vibratechnics gearbox Mount, OZ 17" Superturismo Alloys, Bell FMIC, LED Side lights, LED interior Lights, Tinted Windows, Eibach Sports Springs, K&N Air Intake, 3" Sports Cat and Downpipe, Debadged, EST Strut Brace, EST Grille, Black Moose Stickers, Bilstein B8 Dampers, Fully Polybushed, CC3 all round, CF Wingmirrors
Release the Monkey inside of you >>> Trunk Monkey
Thanks for that I take it Rufe is the best bet for dampers?
