They look good on the mantle piece, but I've now got all four corners to fit... let's the investigations begin....
thanks to our US friends...
Current Garage:
*Data Sept 2013
very nice
how hard r thease to fit? as i no some1 who works for porshes cup team and they bin them and i can get them they might need a clean up and take a while to get all 4 but if its a easy swap i might go for it
As per Woking Rob, what is the price difference between these and an AP set - and what are the major differences. For example, the AP discs are 320mm - what discs does the Porsche set-up use, and does it require a custom made carrier?
KISS Rs
850R manual, Rica 310, IKEA fitted bathroom, H&C running water, Jetex 2.5", pipe rack, cap stand, Forge BOV, circular wheels with full 360 degree rotation, 302mm discs, IPD front and rear anti-roll bars, numerous shiny features, sub-atomic particle accelerator, VTOL capability ...Volvo With Attitude!!!
Also to be seen in a gold Honda CR-V these days...
"It's really fast, and growls like a tiger!"
You could always make it easier on yourself Judge and give me a pair, that way you've only got to fit one set, not two.
Previous cars:
i dunno 17 is the smallest wheel they will fit under thats the smallest disc they use but i might b able to get carbon discs aswell will just need to get the volvo bells,
Previous cars:
Flatout Phil (Sunday 7th March 2010)
Yep I'm after a set of 330mm discs... I'm going to be doing this when I've completed the two essays that I was supposed to have written by last week!!!!
Current Garage:
*Data Sept 2013
So what is the cost difference? 330mm discs and those callipers must give AP a run for the money - though I guess it is a case of diminishing returns.
KISS Rs
At a rough guess the AP is in the region of £1500+ for the fronts only..
I am hoping to complete my modification for quite considerably less and have all four...
The only unforseen expense was a bit of import tax that put the calipers at £175 each.
Current Garage:
*Data Sept 2013
KISS Rs
You have to remember that I've bought both fronts and rears from a Cayman S, so it shouldn't reach anywhere near that for the fronts alone. I'm expecting my fronts to work out around £500-600.
Front Calipers (£350)
Braided hoses (£50)
Discs (£120 - 150)
Pads (Already supplied)
The rears are going to be a bit more as I thing I'm going to have to buy a few different brake discs to get a set that are compatible. I haven't even started to look at them yet..
Current Garage:
*Data Sept 2013
Flatout Phil (Tuesday 9th March 2010)
It is certainly a mod I would consider at that price. I look forward to hearing the full story as it develops.
KISS Rs
Interesting fact I've found out is that the all the internal drum brakes are all 177x25mm. This could mean that nearly all rear discs "could" fit to the hub atleast....
It looks to me,even though I haven't actually seen any discs yet, that a 308mm XC90 disc might be the best option for the rear which seem to match up with the specs of the Cayman discs:
Rears - Vented only.
Cayman : 299 x 24
S60R : 330 x 28
XC90 : 308 x 20mm
...or does anyone know what the minimum disc thickness of a S60R disc could be machined to???
Current Garage:
*Data Sept 2013
Flatout Phil (Sunday 14th March 2010)
have you seen these on ebay....
might be usefull.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Flatout Phil (Sunday 14th March 2010),JUDGENINJA (Sunday 14th March 2010)
In a Blue Peter style.... here's some I bought earlier!!!!...(if I could be bothered to get the camera out)
Thanks anyway, but I've already got all the calipers I need... I'm just thinking out loud, maybe someone might log on that has already done this and be able to warn me off doing something stupid...
Current Garage:
*Data Sept 2013
You are probably well aware, but noticed a Swedish site yesterday that sells conversion carriers so you can use rear S60R callipers on 850. If you don't know about it, let me know and I will send you the link. That said, as you have the Cayman discs, this may not be much use.
KISS Rs
.... ah I think I'm having a Sunday mis-understanding session....
I've got Calipers...
I've not bought Discs yet...as I said I've not actually seen any discs yet. I just doing research..
I'm looking at probably going to buy XC90 discs as they suit the deimensions better as they have to be able to fit over the 850 drum brakes..
Current Garage:
*Data Sept 2013
KISS Rs
JUDGENINJA (Monday 15th March 2010)
Current Garage:
*Data Sept 2013
