IMHO when I did the freedom test drive - V70R MY2006 vs the same year S60 T5 - I found the S60 T5 more fun to drive, the 2.4L T did not seem as encumberd with the AWD which IMHO makes the car feel solid but more sluggish.
I would also worry about modding the later Rs - they have too much metal taken out of that block. I hear nightmare stories about cracked liners!
Volvo ABS ECU Repair
thebadger (Tuesday 9th February 2010)
I drove a Brera with 265bhp and 4wd - it felt SO slow because the traction was perfect!
sometimes a little drama adds to the occassion, you need big power to push a 4wd system... OK so it'll be more refined, faster and quicker point to point...
... but you won't get as sweaty and excited driving it there
2319cc Using a 16T turbo.
You think I know **** nothing! But let me tell you I know **** all!
In the later models, yes, but initially the T5 engine remained the same, ME7 2319cc 16T. The revised engine I believe came in with the 2004 facelift. it was a 2.4lt engine but iirc still used the 16T.
Here ya go
http://forums.swedespeed.com/zerothread?id=74265
Variant 1 - Base
Variant 2 - low pressure turbo
Variant 3 - high pressure turbo
Variant 4 - AWD
Variant 5 - XC
Variant 6 - R
Engine Information:
2.4 -
168 hp
Superior fuel economy
Continuously variable valve timing
Advanced emission control
2.4T -
197 hp
2.5T -
208 hp / 236 lb-ft @ 1500 - 4500 rpm
Dual continuously variable valve timing
T5 -
247hp
R -
300 hp / 295 lb-ft @ 1950 - 5250 rpm
Double overhead camshafts, 20 valves
Dual Intercoolers
Stereo Information:
Speaker sizes
Head Unit models
Common Problems & Recalls:
2001 –
Variant 1 - Base - 2.4 non-turbo
Variant 2 - 2.4T - 2.4 low pressure turbo
Variant 3 - T5 - high pressure turbo
Variant 5 - XC - 2.4 low pressure turbo + AWD
2002 – Non XC AWD trim introduced.
Variant 4 - 2.4T AWD - 2.4 low pressure turbo + AWD
Variant 5 - XC AWD - 2.4 low pressure turbo + AWD
2003 – The AWD system was updated for 2003+ to a newer haldex electronic system. The AWD models got a displacement bump from 2.4 to 2.5 Liters. The V70XC AWD was renamed to the XC70 AWD.
Variant 4 - 2.5T AWD - 2.5 low pressure turbo + AWD
Variant 5 - XC AWD - 2.5 low pressure turbo + AWD
2004 – The R trim level was introduced. The 2.4T was updated to 2.5T for the non-AWD model.
Variant 2 - 2.5T - 2.5 low pressure turbo
Variant 6 - R AWD - 2.5 high pressure turbo + AWD
2005 – The 2.5T AWD trim was dropped.
New center stack dash layout, new cup holder design for front passengers
2006 – The T5 was dropped for '06?
2007 –
XC70 has gauges similar to the R but with a black face.
Front side blinkers are now integrated into the mirror housings
Looking for a V70 Sport D5 geartronic
MisterC1501 (Sunday 7th February 2010)
Sacked the secretary. This is weird....even thou mine is plated as an '03 the car itself is only recognized as an '04-.
The above information would confirm this as the R AWD trim wasn't brought in until 04. Anyone care to comment?
I would say that that above info maybe incorrect as i have an V70/S60R brochure and it is dated 2003. So that would imply that the variant 6 - R AWD 2.5T (high pressure turbo) was indeed introduced in 2003 and NOT 2004.
I've got a 52-plate car that was registered in 2003... it does happen.
Alastair
enjoyed reading the various information
the 2.5 engine in the late volvos is the same engine as the 2435 lpt engine all they did was put a longer stroke crank in it .i know this when i built my v70 lpt engine 2435 i fitted s60r conrods and pistons in the block which by the way are forged to take the extra stress.and when brought the piston up to tdc the piston crown was down the bore about 1 to 2 mm .which was good for me running a bigger turbo and lower compression.but it is only the R models that have forged rods
Ha Ha... The only cars tested by the Top gear loons were a green S60R and a green V70R.
The bits have all been replaced cos the second owner was minted (shoulda seen his house!!) and i guess money was no object. In the period from April '07 to the day he handed over the car to me Jan '10 he had it into the dealer 4 times for normal servicing and remedial repairs and the total price of all the invoices is a cool £5403!! That's £163 a month on servicing and repairs.
Tomorrow my car is in the garage having the front spring seats replaced, the rear wishbone bushes replaced with new oe and the front wishbone bushes with powerflex bushes. Also the Diff oils checked/topped up and the Exhaust manifold >> downpipe bolts need tightening up (it's blowing a little on cold start up).
