Originally Posted by
Tomcat
As Pete's suggested, cut the cable ties that are securing the wiring into the S shaped ducting on the back of the housing, after that it's just a case of undoing the screws around the outside edge of the heater motor (the black part), you should have enough room to wriggle the heater motor out of the housing. On the back there's a small screw with a washer, (In the middle of the photo), undo this and put a couple of dops of oil into the hole(not a lot), leave it to soak for a while and then put it all back together.
