I defo admire the intensity Dave!!!! Goes way over my head though.... unless I can see and touch something it's all Greek to me
WHY DOESN'T MY SIGNATURE WORK??? ...IT DOES NOW! :-)
Wobbly Dave (Tuesday 24th March 2015)
Let me illuminate you then. There was a discussion on social media between myself and a nottingham-based volvo specialist - Shemtek - that perhaps I should be disappointed with the results of the turbo and some of it may be down to higher than normal exhaust gas temperatures EGT. Shemtek said that I had the wrong turbine housing and that the one I had bought would be artificially increasing the EGTs. This is all purely conjecture without some proof. So I was looking to Dream3r to provide me with some data logging so I could get the WOT values for EGT amongst other things. At the moment the amount of data I have is limited to merely 10 runs on HLM's dynojet from last year.
https://youtu.be/1Kc7zyr9KLc
There probably is some wisdom in changing the collector after the turbo to either include a separate exhaust pipe just for the wastegate...
using this flange that works with the GTX housing
as opposed to what I have right now -
or even a wide mouth collector welded onto a 5 bolt flange.
Volvo ABS ECU Repair
Even though the space is tight - I think the dedicated 2" W/G exhaust pipe is a better option as it means minimal changes to the actuator. Removing the V-band and altering the DP slightly is much easier.
I don't know why I imagined that the value could pull it off the top o2 sensor - derrr!
Can I wire one in? (goes off to the internet to find out)
My blitz i-color sadly cannot be expanded to include EGTs - only AFR and I would have to buy the MMD upgrade to include it and even then There are 2 plugs for optional sensors. One is strictly for Temperature and the other is for either Pressure OR A/F Analyser.
The unit is not able to display both Pressure and A/F.
Blitz's EGT standalone gauge is quite expensive at 200 quid.
Not sure which gauge to get.
Do I really need to tap my exhaust manifold?
that's what the advice seems to say. The guy (Chris) is pretty knowledgeable if you give him a call. I was thinking about getting one for the Renault and would need to go into the manifold also if I wanted to fit the sensor before turbo..although that is a tubular one so would be less of a worry - drawn piping as opposed to a cast item
Would it not be easyer to change the turbo all together?
http://www.terrabear-newfoundlands.co.uk/
You always come back to what you know !!!
13.8@ 103mph fastest forum 850 in 2010 Running 286bhp(former owner)
I think the main reason Dave isn't getting the power is the modified 19T map, I think if it was mapped properly he would see in excess of 450bhp, although I still question the size of his boost pipes and I would be inclined to change the exhaust housing for something like this.
http://www.ebay.co.uk/itm/Downpipe-F...item3f46255d89
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
jamesy12345 (Wednesday 25th March 2015),p fandango (Wednesday 25th March 2015),Rnash2002 (Wednesday 25th March 2015)
Yosser was very successful getting his (now my) S70R custom mapped for the mods on his car - I think the forum should have a whip round and fund 3 new maps from different tuners for comparison for Wobbly, in the name of science . It's not all about peak numbers anyway....depends how the car drives & what it will be used for.
Rnash2002 (Wednesday 25th March 2015),Wobbly Dave (Wednesday 25th March 2015)
