just a bit of suitable shim and some araldite or smiliar... simples
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
Volvo ABS ECU Repair
yep, that would do. I've got plenty if and when you need it.
PIC][/SIGPIC]
Wobbly Dave (Sunday 28th July 2013)
Saturday - I picked up my old engine which had been sitting out the back of HLM. I'd already had the sump off it due to a sump plug weep issue.
Had just a few hours spare today so I got both oil pumps off. I had a mare with one of the hex bolts holding the 2 halves together. In the end I had to cut a slot it in with a dremel grinding wheel & use an impact driver & a hammer to get it to budge. Really annoying when you have limited time. Anyway - I got to use the cleaning bath my wife bought me in 2011. Both have the metal caps as previously discussed - so I am not sure which I should use?
I've sort of got to a point where I am unsure how much more to do I need to remove the crank out of my old engine - if I do take the crank out of my dead new engine - what do I look for in the big end shells? Would now be the best time to throw the hole thing to an engineering firm/engine builder - so they can diagnose the faults?
Should I use my big red tank to clean the block up? Any cleaning tips would be appreciated.
Yes IMHO. You've probably learnt a lot in the process and I certainly admire your efforts this far. My 850 is sat on the drive way with a blown engine, no way I'm even going to attempt it, but I know a man who is at the top of his game and once I've saved my pennies it will be straight to him on a trailer.
If your old Engine was working fine??? then I would use that! but only if it had no known problems?
My T5 Engine came from an Auto T5 (so not had a hard life) as the other one had a rod go through the block, the serial numbers where taken from the crank to get the correct size shells, there was a 1000th of an inch skimmed of the liners and OS1 pistons fitted, China rods fitted, the head was ported and flowed, even the intake and outtake right through to the zorst, new valves re-ground and fitted, TTV fly wheel fitted VXR injectors and it's been fine ever since! touch wood!
I firmly believe you are throwing money away by keep going to engineering firms asking them to do this and that and commissioning them? As all businesses will take a persons money, You need to find one person not a firm, I am sure there are a few builders on here who could do a build all day long! rather than a Engineering firm or builder or you are going to spend a small fortune again, the recipe for a solid engine build with all sorts of power & turbo's has been posted time and time again over on T5D5 and they are still going strong today!
I think you should have a good read over on T5D5 and ask questions here and there before you part with anymore of your hard earned money and then make a discussion, as no one wants to see thing go wrong for you again Dave!
Cheers Greg
I Reckon I am Perilously close to 592 Bhp With all my non dangerous Mods
claymore (Monday 29th July 2013),S70T5Chris (Monday 29th July 2013),T5frankie (Monday 29th July 2013)
The old engine was using water & had shown that the H/G was on it's way (confirmed on a sniffer test). That doesn't matter so much to me.
My RCA is going nowhere - I am no closer to the truth about where the oil went. Turbo has a clean bill of health. The 2 oil pumps look identical & I still don't know if pushing on with ME7 will even work.
I am under some pressure to get the job finished by her indoors & then not touch it again for a long time. I can't give her any assurances. Perhaps the whole notion of pushing the 2319 this hard is flawed?
Root cause analysis - something I have to deal with a lot in IT problem solving.
Doubts about the ME7 in terms of throttle response. I have to ask it & if the ECU on closed loop says it's not going there it can override me - at least that's what I think it does, which is not condusive to a decent 1/4.
The whole purpose of the on-demand throttle is to make it smoother because the engine can control the phased cam timing, which if I understand it correctly alters the relative position of the exhaust cam.
Only way to program around it would be to go simpler. Delete the VVT cam & use a vernier pulley (which in itself is a compromise) and return to a manual cable throttle.
Simply means buying 850 which I'm not sure I want or preferably a 1998 C70 which are virtually impossible to find. The auto is not a problem because the gearbox swap would have to happen.
That's a lot of headaches & Wife-based grief just to set a time?
Other option is - I cut my losses now - sell up and move onto something else.
dont quit dave. even if you had to bolt the subframe back on and get itback on its wheels and park up in the corner for a few months. if it was me in your position id be doing on of two things. it either be buying a engine stand and doing the work my self as and when feel like it. or bite the bullet and ask tim willams if hed be willing to rebuild and fit engine. with out doubt hes one of the most trusted people inthe world of volvos and he knolodge and experience will help you like no other can. youve gone to far to quit now.
claymore (Monday 29th July 2013),partsforvolvos.com (Monday 29th July 2013)
Already have an engine stand, I don't have the precision engineering tools or experience to make this work.
I am more uncertain about the ME7 as a design - just like no-one would run a standard geartronic g/b to go down the drag strip either.
John (Dream3R) has been doing some ME7 programming. I don't know why you're worrying about vvt - it might make a 5% difference to the finished performance. Ignore the vvt. You just need control of throttle opening, fuelling, boost and spark advance. The "point" of ME7 is emissions control and engine protection.
2005 (163) V70 D5 SE Premium Pack 130k. 10" sub/Fli amp with Grom audio kit. Shark stage 1 with EGR delete and 320mm discs. Enjoying the comfort and (relative) economy.
befor you get to far into the build again id be speaking to the likes of shark performance and see what they say about mapping this kind of management. ask as many question to as many people who have the proven knolodge of these systems and builds. i know nowt about ME7 so thats about the only advise i can offer.
