Page 58 of 113 FirstFirst ... 848565758596068108 ... LastLast
Results 1,141 to 1,160 of 2254
  1. #1141
    Clueless about Cars
    iancho's Avatar
    Sep 2009
    Just outside of Oxford
    3,314
    I don't know what to say Dave it appears nothing will go right for you at times after all the effort you have put in... I feel for you and hope that a solution can be found... Gutted to be reading this.
  2. The Following User Says Thank You to iancho For This Useful Post:
    Wobbly Dave (Friday 19th July 2013)
  3. #1142
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by Wobbly Dave View Post
    There is evidence of some piston slap - I looked again at the bottom of the cyl. head on #2 - if you look carefully at the 2 edges of the piston crown & the sides of the valve recess there are matching shiny bits.
    My next door neighbour is a mechanic & I showed him - it was something I had not initially spotted.
    He is of an opinion that the cap bolts have some how come loose.
    That was my initial thought, I think there's too much movement for a spun bearing.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  4. The Following User Says Thank You to claymore For This Useful Post:
  5. #1143
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Found my bearing.
    took a while to get the sump off. Spent ages trying to pry it off once all the bolts were removed but it wouldn't budge. In the end - I lost my rag - got a long piece of wood put it against the empty dip stick hole and hit the wood - hard - wivanammer.
    That shifted it. I also had to bend down the flange that welded to the side of the subframe.
    There is no good news I am afraid. End cap bolts on number 2 were intact. Less could be said for the big end bearing - no so much spun as completely vanished. Rod cap & big end on the conrod look like they've got slightly warm (slightly in the sarcastic way).
    Anyway I found my bearing...
    and here..
    look there's some more...
    The end of no 2 looks like someones been hitting it with a axe
    I am sure it is not supposed to be that colour...
    I don't have a micrometer but wisdom would say that the crank is fit for the bin and maybe that conrod too.
    I don't have much faith in the block - because something has gone wrong with the oil supply, right?
    It's all gotta come out. I am not a happy bunny right now. Back to the drawing board. This time I am going to build it right.
    Volvo ABS ECU Repair
  6. The Following 5 Users Say Thank You to Wobbly Dave For This Useful Post:
    iancho (Saturday 20th July 2013),Jamest5r (Saturday 20th July 2013),JT (Saturday 20th July 2013),smithy (Saturday 20th July 2013),theflyingbrick (Saturday 20th July 2013)
  7. #1144
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Sorry to hear this Dave, was hoping for a better outcome for you.
    Glad you are continuing with the project though, like I said earlier this is a 'one of a kind' build and when you have it finished 'Betsy' will be one hell of a quick motor.
  8. The Following User Says Thank You to V70 Graham For This Useful Post:
    Wobbly Dave (Saturday 20th July 2013)
  9. #1145
    dtp's Avatar
    Feb 2009
    Malvern
    23
    Not good news Dave. Did you use a new Volvo oil pump as a few have had issues with them on their rebuilds.
    I think it's time to source a low mileage 2.4 T5 engine and start from there. (Use the original oil pump with the new engine)
  10. The Following User Says Thank You to dtp For This Useful Post:
  11. #1146
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Gutted for you Dave. After all the time, effort and money you've put into this, for that to happen is a right kick in the made. You have far more patience than me, I think if I was in the same position I'd have taken a match to it by now.
  12. The Following User Says Thank You to stribo For This Useful Post:
  13. #1147
    Trader
    Nov 2010
    chester le street
    969
    dave im realy gutted for you. i wanted to be wrong about the the shells. previous experience had me almost sure it was what you found. is the crank realy bad. it get it checked out. you may get away with a regrind and oversized shells. i dont think youve done anything wrong on the build. youve just been very unlucky. i didnt see any corners being cut. keep your chin up dave and if i can help with out let me know.
  14. The Following User Says Thank You to graemewelch For This Useful Post:
  15. #1148
    Moderator
    NOS
    WOODY T5's Avatar
    Sep 2005
    hull
    2,573
    Gutted for u Dave after all that hard work but stick with it son will come very good after the rebuild
    "WOODY T5 fastest volvo 850 since 2011/12/13/14 @ avon and york 13.3 112mph
    854 t5 19t gripper mte bc loads more 311.6 whp 373 foot pound 342 @ clucth
    toy cbr954
  16. The Following User Says Thank You to WOODY T5 For This Useful Post:
  17. #1149
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    I have another crank in my old engine - so that's one option. I have no idea why this shell self-destructed - other than some low oil condition existed and how that occured is a mystery.
    The crank didn't look bad (but I don't know what a bad crank looks like) but it would need measuring.
    Little end bearings all feel fine.
    the oil pump was new AFAIK.
    I think I will be installing oil temp & pressure sensors - so that something like this cannot happen again - or if it does I can catch it before anything bad happens.
  18. #1150
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
    Curiously enough dooby's car seized on no.2 when it failed, is there a reason why no.2 would go first?
  19. #1151
    Trader
    Nov 2010
    chester le street
    969
    wise move with gauges. heres a pic of a bad crank from megane dci i rebuilt earlier this year
  20. #1152
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Comparing just 2 of the lowest journals (I couldn't be bothered to get my tools out just to take the photos)
    Journal 5...
    vs
    Journal 2...
    Whaddaya think?
    To me there seems some of the edge missing but I can't really tell - they just look different.
  21. #1153
    Trader
    Nov 2010
    chester le street
    969
    youll get away with a polish on that dave. at most youll need a new conrod. youve been very lucky. that could of wiped the crank out. conrod might even be ok. any close up pics
  22. #1154
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Can that happen in-situ or does the crank still have to come out?
  23. #1155
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Really bad news dave I really do feel for you as for the polish of the crank it will need to be removed and sent to a machine shop for a polish or re gring then polish
  24. #1156
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    That looks alright to me Dave, I'd expect a lot more signs of massive heat like in Graeme's picture for it to of bent or warped.
    Bad luck mate but it could've been a lot worse. A polish wont cost you a fortune. Just the labour involved removing it really.
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  25. #1157
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    But given I have a spare crank - which would be the best to use?
  26. #1158
    deathrider311271's Avatar
    Apr 2011
    Grimsby
    483
    i would put money on it being the oil pump at fault here, there have been several cases of this on new engine builds, Dave speak to Tim Williams he has a solution to the new oil pump problem.
    P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
    Previous: 2004 XC90 T6, 240GLT Estate, 343DL
    Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
  27. #1159
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    what fault is that?
  28. #1160
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by deathrider311271 View Post
    simon do you mention Tim williams in every post? lol
