Page 55 of 113 FirstFirst ... 545535455565765105 ... LastLast
Results 1,081 to 1,100 of 2254
  1. #1081
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Well I deliberately have done FA with the car today. Smithy reckons I need a new VVT pulley - so I will probably order one tomorrow.
    Volvo ABS ECU Repair
  2. #1082
    smithy's Avatar
    Apr 2006
    1,752
    It's only a thought because they have been known
    To go and that would also explain
    The cam timing being out.
  3. #1083
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    My only other thought is that the centre nut is loose?
  4. #1084
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by Wobbly Dave View Post
    Has yours still got the Torx drive cap fitted if so just remove it to get to the nut,I can email you the dealers guide of how to set it up if that woulD help you. It does sound long winded way but thats what they say.
  5. #1085
    Jul 2008
    0
    My VVT was out but it didn't take Tim long to resolve the problem. Quite a few get incorrectly set up and I'm not even sure that all main dealers can get it right. Symptoms can be subtle but erratic idle and driveability issues are common - sometimes not diagnosed as the ECU allows a wide range of adaptation in VVT operation and symptoms can consequently be intermittent with misleading codes. I'm not sure how reliable the units are but just be sure it was set up correctly before buying a new one - a quick Googling suggests that they are north of £100. I'm not knocking your skills in aligning it just letting you know people §§§§ the process up reasonably frequently!
    2005 (163) V70 D5 SE Premium Pack 130k. 10" sub/Fli amp with Grom audio kit. Shark stage 1 with EGR delete and 320mm discs. Enjoying the comfort and (relative) economy.
  6. The Following User Says Thank You to jardon For This Useful Post:
    Wobbly Dave (Sunday 14th July 2013)
  7. #1086
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by jardon View Post
    your idle was very erratic Dave
  8. #1087
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Torx T55 holds the cap in place. thanks for the offer of help - all information would be gratefully received.
  9. #1088
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Too §§§§ed off with it to even bother lifting the bonnet today.
  10. #1089
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Well a new day dawned & it's still nice outside. Finally figured out what I was doing wrong. By winding anti-clockwise against the crank locker - this was allowing the exhaust cam to wind backwards against the VVT - thus making it look like the cams are not aligned. I am satisfied that the timing is good for now. Good enough to try the compression test again.
    So I have tensioned the belt again & reinstated the starter. Bad news is the battery is too flat to retest the compression. Wife is stealing the diesel to go to see her parents & I don't have a battery charger - so I'll have to get on my bike and go down to Halfords.
    Either way I think I will still replace at least the bolt holding the VVT pulley on if not the pulley itself. TBH I don't really know how to tell if the VVT pulley is faulty or not - just that I'd feel happier replacing it.
  11. #1090
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Let's hope that was all that was wrong.
  12. #1091
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Major big thanks for sending me the instructions
  13. The Following User Says Thank You to Wobbly Dave For This Useful Post:
    Harvey (Monday 15th July 2013)
  14. #1092
    Trader
    Nov 2010
    chester le street
    969
    fingers crossed for you. im fairly confident that this is the problem and you wont need to remove the head. will you still be sending the turbo off to be checked over
  15. The Following User Says Thank You to graemewelch For This Useful Post:
    Wobbly Dave (Tuesday 16th July 2013)
  16. #1093
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    turbo came off last week & went to Turbo Dynamics - intial feedback, when I spoke to Tom @ T/D yesterday is that bearing feels ok to him - but they are going to strip it down to the CHRA, put some oil pressure through it & spin it up on their balancer any way just to be sure.
    I have essentially stripped the top half of the engine back to just the bear head. All that remains on it are the cams, belt, rocker cover. I too am praying that against the odds I have gotten away with it.
    Battery last night was only just strong enough to lock the car. So I unlocked it, left the bonnet on just the safety catch & pushed the tabs down by hand.
  17. #1094
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Bad news I'm afraid. Battery is charged
    1 came up to 12 bar. 2 is still down at 10 bar - rest are as they were - 12 bar.
    Guess I have no choice now but to take the head off. Bummer.
  18. #1095
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    That doesn't sound good mate, lets hope it hasn't damaged a piston as well.
  19. The Following User Says Thank You to stribo For This Useful Post:
  20. #1096
    Trader
    Nov 2010
    chester le street
    969
    as above hope theres no serious damage and its a false alarmmight be worth droping a bit oil.in cylinder no 2"and doing another test just incase ifs dry. ill keep my fingers crossed for you
  21. #1097
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Can I do a compression test now that the rocket cover & the cams are out? Probably not.
    Well there are no marks on the cam lobes - and the tops of the lifters (silly name really - surely "pusher downerers" is better LOL) look fine.
    Nope tomorrow the head is coming off. Then I might know something - or I might stand there scratching various body parts (not uncommon for me - LOL).
  22. #1098
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    Keeping everything crossed for you WD. Be a shame for it to dent your wallet after building such a bang on engine. Like your term for lifters too.
    Ps that picture of it on 19's you posted is possibly the nicest c70 I've seen. You need those wheels back in your life even if it does look a right sleeper on the comets.
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  23. The Following User Says Thank You to Biff For This Useful Post:
    Wobbly Dave (Wednesday 17th July 2013)
  24. #1099
    Trader
    Nov 2010
    chester le street
    969
    cant see why not. all the valves will be shut. just take plugs out of pot thats not getting tested
  25. #1100
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Tell that to the thieves that half-inched them.They were imported from the US & cost a lot of dosh. Company that sold them to me no longer exists.
    I am thinking I will do some extra bits on the pieces I have off. Improve the head a bit more.
    Polish the exhaust manifold & get it coated. Get the DP coated too.
    Not looking fwd to finding that my cylinders are goosed or something else even worse.
