Hello all,
i've just had an aircon re-gas and no leaks (checked with the dye / UV light) after a week.
however,
the compressor doesn't kick in at all and there is no audible 'click' from inside the ECC unit. the garage said that there is no live feed to the compressor (?) and i occasionally get the 2x orange flashing lights of doom....
also, the passenger side vents always blow warm irrespective of the temp setting on that temp dial
my question is - does this sound like a knackered ECC ?
does anyone have a known working version for sale ? (or know of anyone who may have)
it would be nice to swap one over to test it first i guess but i would need someone who has a spare one who is prepared to let me fit it and try (local to me would be ace)
as a bit of a novice at these things - do you remove the radio then push the ECC out from the back (i assume there will be some electrical connections to remove too) ?
sorry for the long post - i'm a bit stuck as to what to do
