danny-R (Friday 30th April 2010)
not exactly what i wanted to hear, but you could be right.
i don't think i will bother doing that tomorrow then i'll just run it into the ground instead .
don't worry i will still be going to york if it's smoking or not cos it friggin flies still
tbh i couldn't afford to do it anyway, my best bet is to drive it till i need i new engine then source a decent one to replace it.
i didn't even bother looking at the pcv today, i will just have to live with it.
I really wanted to reach 200,000 on this engine doesn't look like it anymore
Do you need an inlet gasket or do I need to buy anything other than the kit from rufe?
Cheers
right, thought i'd post up in the original thread to keep everything in order. Sorry for the cr4p pictures but think you can see what i've done. got a 28mm to 19mm 90degree reducer, 19mm T-piece & 19mm silicone pipe. It doesn't sit very well on the crank breather (keeps sliding off) so going to order a 19mm 90degree, then possibly another 90degree so theirs not too much tension on the pipe & run it across the top of the injectors. Also got to see if i can get a 19mm port for the top of the catch tank, or it'll have to be a 19mm-15mm 90degree reducer, plus need to order some 19mm alloy tube to join up the block breather to the other pipe, i'm tempted to do all the long runs in alloy with silicone joiners on the ends
got to order some more joints to sort the crankcase breather
easier to see what i've done with the manifold removed, you can't see the sump bung too well tho
Jamest5r (Monday 5th July 2010)
So where does the clear pipe from the catch can go? Back to the air intake pipe?
S60 D5 Sport - everyday cruiser
Volvo 850 T5 Turbo - Toy awaiting reconstruction
it can but your better off just venting to atmosphere, if you put it back into the intake the oil fumes will still contaminate the air/fuel so no benefit to fitting the catch tank in the first place. The clear pipe is just to get the fumes out the way so they don't get fed into the cabin (normally thru the heater intake on the passenger side skuttle panel)
T5hug (Sunday 4th July 2010)
Is the whole point of this not to eradicate those oily fumes though!? I still have the standard air intake with the little sensor (can't remember what it's called!!! P**?) will plugging this be ok if doing away with the pipe? Could I not just vent the original PCV to atmosphere assuming it's all new and clean!?!
Sorry for all the questions!! Lol!
lol no problem, the standard PCV feeds oil & gunk thru the vent pipe back into the air intake pipe thru the little sensor your on about (its actually a small heater element). This gunk contaminates the air/fuel spoiling the mixture & worsening the burn/explosion, thats the theory behind it. The catch tank keeps the gunk out of the system so should have a better fuel/burn mixture
the small element in the air intake isn't measured thru the ECU so can be unplugged without the ECU throwing a fault code, i'd only block & remove it tho if your running a seperate catch tank & venting to air. As said the PCV lets some oil thru & will make a mess of the engine bay if you simply disconnect it, some racetracks won't let you race if your venting to atmosphere without a catchtank
Ok cheers! so even my new pcv will still allow oil etc back through!? Aaargh!!! Ha!
Had thought about a catch tank before but decided to replace the pcv!! Do you think the catch tank is still worthwhile after the pcv tank!? It's all new so no point in binning it! Is there!?!
i only know of one person (Russ) running without a PCV, everyone else runs the catchtank inline. I'm only just experimenting with removing the PCV & tbh its all theory work so far, BT's engine isn't ready to be run again yet so not sure if we'll come across any unexpected problems running without one
Catch tank it is then!! I'm determined to get rid of as much oil as possible! The car had oil leaks everywhere so slowly eradicating them one by one!! Burst pcv Hoses and the oil filler cap plus a burst boost pipe had my engine bay in some mess!! But tbh it could have been a lot worse!!
Slightly off topic but after sorting the pcv can anyone recommend a good way to flush the intercooler of unwanted oil and crap!?
T5hug (Monday 5th July 2010)
i've just ordered hopefully the final lot of bits i need to remove the PCV, i'll post more pics once i've got everything fitted. Its basically the same set-up as i've posted above, but looks nicer lol
an update for ya James
got to get Powerflow to bend a pipe for the camshaft cover to the T-piece. The 90degree bend to connect the pipe to the catch tank should be here tomorrow
Looks so simple in the flesh!! just get the damn thing started now and see how it performs, personally i would get rid of the catch tank and just vent straight to air from the block, you got to think about the weight at least a kilo there lol
p fandango (Tuesday 3rd August 2010)
