how much turbo boost psi, should be in 1st, 2nd, 3rd, 4th, 5th gear? on mine in 1st and 2nd is 10psi but in rest of gears its 12psi.. is this right?
cheers
cheers
http://www.terrabear-newfoundlands.co.uk/
You always come back to what you know !!!
13.8@ 103mph fastest forum 850 in 2010 Running 286bhp(former owner)
Boost is generally limited in lower gears to reduce wheelspin (although not sure how the ecu tells which gear its in, must go on speed and rpm)
aye mate its standard... just fixed a split pipe which was on it, must of been split since i got the car as it was only boostin about 8psi in 3rd 4th 5th
what is standered psi for a standered 850 t5 ?
IIRC 9.5psi, about 3/4 into the white bit of the guage
