Results 1 to 16 of 16
Thread: Abs Ecu
    Junior Member
    Nov 2004
    0
    Abs Ecu
    Hi, I have just signed up and own a 96/N 850 CD estate.
    Having owned it for nearly five years with no real problems, things have now taken a turn for the worst.
    In addition to a bust ACC (they all do that sir!), my local garage has diagnosed a faulty ABS ECU and have quoted £400 me to fix it.
    I can get a replacement unit for approx. £100, but need advice on how easy (or otherwise) it is to swop the unit itself.
    It would be great if you can post a picture where it is located and detailed steps on what I need to do.
    Aug 2004
    Braintree, Essex
    0
    Its easy to replace,
    But save yourself £70 and take a look here
    Regards
    Steve
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
    Junior Member
    Nov 2004
    0
    Thanks.
    By PM I assume you mean "Private Message" - apologies for being a newbie.
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by DSteel
    Thanks.
    No need to apologies my friend, yes pm is probably the most reliable way to get ahold of him, failing that give me a should and I'll did his number out
    He'll sort it good as new
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  5. #5
    Member
    Oct 2004
    0
    my ABS light has come on briefly recently only to go off again after a short while? any ideas or does it have a code system to read like the ecu. Taking it in thursday to have a look.
  6. #6
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by fireplums
    What car have you got and what year is it ?
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  7. #7
    Member
    Oct 2004
    0
    its 850 t5 cd auto 1997..... by Volvo
  8. #8
    Aug 2004
    Braintree, Essex
    0
    Have you this diagnostic port in your engine bay at the front on the left by the windscreen washer bottle ?
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  9. #9
    Member
    Oct 2004
    0
    no dont think so i think its in the car by the gear stick?
  10. #10
    Aug 2004
    Braintree, Essex
    0
    Ahh thought so, was just checking, your OBDII and will need to find a Volvo garrage that has a reader, I would recomend Adam @ Volvotuning, but without knowing your location I can recomend any others ?
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  11. #11
    Member
    Oct 2004
    0
    Cornwall ! hence no Rica and the Upsolute mail order option
    the cars in for a bit of a service on thursday so I'll sort it then
    off for a little spin in the beast now
    cheers
  12. #12
    Aug 2004
    Braintree, Essex
    0
    cheers
    Right let me make a few call and see who I can come up with
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  13. #13
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    David - I have sent you a PM. The only slightly tricky thing about removing the unit is that the screws face downwards and space is a little confined. You can remove the airbox to make it easier to get in.
    If your ABS light comes on and off regularly I can almost guarentee that the ABS ECU is on its way out. As Bracer said - I can repair them (on a no fix no fee basis)
    Volvo ABS ECU Repair
  14. #14
    Aug 2004
    Braintree, Essex
    0
    Have No Fear Dave Is Here
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  15. #15
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    The ABS ECU in this picture is in the bottom left hand corner (ignore the arrows) the pump is just above it (thing with 4 copper pipes coming out of it)
    it is adjacent to the airbox and the pump is next to the N/S suspension turret
  16. #16
    Aug 2004
    Braintree, Essex
    0
    Get and give your oily bit a wash mate
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
