Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Exclamation Grease and wheel bolts!!!
    I have just got my car back from being serviced at my local volvo stealer and tonite decided to look for a nasty noise comming from front end of my car, this involved takin the front wheels off.
    Now the main thing i need to know is does any one no if volvo or any garage use grease (not copper ease) on wheel bolts on the thread , i thought that this was dangerous as grease is designed to make two surfaces glide over eachother and not stick, exactly the opposite of what i thought wheel bolts were meant to do!!
    Cheers
    Back on the road with 6 gears...........!
    splatt's Avatar
    Jan 2005
    South East
    0
    NNNNOooooo....!!!!!!!!!!!!!!!!!!
    Clean it off....
    On alloys a smidge around the seating but never the thread...
    It even tells you not to in the habdbook.....
    Complain...
    Scrappage.....love it!!
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Ah didnt think it was right stoopid thing is there is a load of copper ease around the hub to stop the wheel stickin on! Y not use it on the bolts too, never mind tho, nasty thought who else may have the same thing from them but doesnt check there car!!!
    Telling off on the way!!
    Oh and as a warning to anyone else in my area its southampton volvo that did it, not happy!
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    You should have a small amount of copper slip on the thread of the bolts and on the hub. The wheel nuts are cranked up tight (80 ft pounds minimum) - and the slip stops them getting seized and stops the alloy from sticking to the steel hub.
    I always do it and always will. Hamish does it. I have never met a mechanic that didnt.
    Volvo ABS ECU Repair
  5. #5
    Andy's Avatar
    Aug 2004
    Geordie Land
    0
    I always do it too, have done on every car i've had and friends etc.
    As Dave says the nuts are cranked very very tight and if you do as tyre places say (check wheel nuts after 100 or so miles) then you should be fine.
    One benefit we have is 5 nuts instead of 4
  6. #6
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Copper ease i no about its the grease on the thread that worried me!!!!!
  7. #7
    madness's Avatar
    Oct 2004
    Northants
    1
    we always do it . getting the wheel off otherwise can be a nightmare
  8. #8
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Quote Originally Posted by madness
    Wot grease (not copper ease) on the thread?
  9. #9
    madness's Avatar
    Oct 2004
    Northants
    1
    sorry i meant coppaslip
    not grease
    it might be a copaslip alternative grease as some people are using this now.
  10. #10
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    CopperSlip is just grease with copper dust mixed into it. It is used to prevent binding and exclude water. Regular grease will not do any harm.
  11. #11
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    So forgive me if im seeming a bit thick here but grease (not copper ease) IS ok on the thread of my wheel bolts?
  12. #12
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    it will not do any harm.
  13. #13
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Ah cool, thank you for clarifyin that for me, thanks all.
  14. #14
    Suspended
    Mar 2005
    0
    Quote Originally Posted by Wobbly Dave
    i would certainly apply copper grease to the faces of the hub but as for the wheel bolts no, i would not, the torque value volvo qoute are for the bolts dry and by applying grease you are actually reducing the friction bewtween the thread flanks , looking at my owners handbook it states in bold print DO NOT GREASE WHEEL BOLTS, enough said really, unless you of course know something volvo dont, the important thing to remember is make sure the threads are clean and in good condition and torque up to bewtween 80/95 llbs ft using a accurate wrench(anymore and you will damage the wheels!) follow this and you wont have any problems it is actually standard engineering pratice when torque loading fastners that no lubricant is used unless specified as this totally alters the friction load applied
  15. #15
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Quote Originally Posted by andi t5
    Ah now that was what i thought in the 1st post!, ill be cleanin them anyway better safe than sorry.
  16. #16
    Junior Member
    Apr 2005
    0
    Quote Originally Posted by jp850R
    good idea, anyone who advocates greasing wheel bolts is a playing with less than a full deck imho, as andi said it states in no uncertain terms in the owners handbook not to, how clear does it need to be for gods sake?
  17. #17
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    I advocate the use of a smallest dab of copperslip. Mine will never jam on. As to my own and Hamish's madness - I may well be. TBH I don't really care enough.
  18. #18
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Copper slip i agree with but grease i do not
  19. #19
    Junior Member
    Apr 2005
    0
    Cool
    er, as dave says copper slip is grease with copper added! therefore the issues with grease apply equally to copper slip
  20. #20
    jp850R's Avatar
    Dec 2004
    Fareham/hampshire
    0
    Oops sorry meant copper ease.
