Hi there I'm a new T4 owner (had it 2 weeks) and I'm loving it, but I experienced a problem with the DSA twice today, each time while I was driving the DSA light came on and stayed on, wouldn't go out when I pressed the button. The first time I was a 1 mile from work so I kept going, once at work I turned the engine off and started it again and the DSA light went out as usual. Went to come home tonight and it started fine and I drove about 5 miles then the DSA light came on again, again wouldn't go out when I pressed the button. At the next set of lights I turned the engine off and started it again, and the light went out and stayed out the rest of the way home.
Does this mean theres a fault with the system? if so does anyone no how I go about sorting it, and is it OK to use the car as normal??
Thanks in advance
