It's back...................and now becoming more frequent Try to start the car and......nothing. I'm tending to lean towards the ignition barrel. Reason for this is that I can use the auto selector and do the usual "through the box for 30 times" procedure to clean the contacts, the "try starting in N position" and the "turn the immobiliser ON then OFF again with the key fob".
For a while, the latter 3 quick fixes each took turns in then allowing my car to start, but I think this could have been just a coincedence.
Anyone else had similar problems, and if so, what cured the fault.
