The offside front window has started playing up, and after our experience with older Volvos (electric windows doing their own thing!), I'd like to fix it before it gets worse.
It goes up and down OK, except when opening, at the very last, as the window disappears into the door there's a loud 'ker-lunk' sound and you can see the glass shift to one side - so it's probably a mechanical problem.
Is it easy to remove the door panels to look inside, and importantly, do they go back in again properly, or are you forever left with loose bits? (I did it once many years ago with a mk 1 transit and the panels were never the same). Or should I let a professional do it?
