Results 1 to 15 of 15
    Junior Member
    Welshlou's Avatar
    Jul 2009
    1
    V70 T5 Air Filters
    Hi there,
    I have a 2000 V70 T5 phase 2 model and I have read on this forum that a change of air filter can make the engine sound a lot sweeter? Is this true, can a change of air filter make much difference to the sound of the engine? If so, please could you tell me what filter would be best?
    I'm also considering an RICA remap - there's a 25% discount for models over 3 years old!! - If anyone has one of these please let me know if it has made much difference.
    Cheers...
    mikouk's Avatar
    Jul 2008
    New Forest, Hampshire
    212
    Hi there.
    Yes and Yes really. I have just fitted a K&N panel filter to mine and it does make a difference. No sound difference as far as I can tell but everythings definately smoother. Throttle pickup is better and general acceleration is better. Not a huge difference but worth it in the long run.
    I also have the RICA PPC upgrade which is amazing. The car is so much better, definately worth the money. It's much harsher than other maps I think but I like it as pootleing around you don't notice it but when you want it you just let the revs rise and feel the thump in the back. However! and its a big however, be very careful with RICA as a company. Their customer service is appalling so get it through a dealer like RT Mechanics. They supplied my car with completely the wrong map and I know they have done the same to many others. I think I was given a C70 map instead of a V70. So be warned.
    Russ at RT's sorted it all out for me though and now the cars brilliant.
    Good luck
    Mark
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
  3. The Following User Says Thank You to mikouk For This Useful Post:
    Welshlou (Monday 27th July 2009)
  4. #3
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    Quote Originally Posted by mikouk View Post
    Is that what the issue was Mark ? I presume the same issue I was having too ? Where did you get this info from ?
    Chris
    2010 Alfa Romeo 159 JTDm
    2001 V70 T5 SE (RICA 310)
    1997 9000 Aero (Abbotted)
    Visit my Rant
  5. #4
    mikouk's Avatar
    Jul 2008
    212
    Yeah that was it. Russ managed to get the info out of RICA eventually. It was some part of the map that relates only to the C70. Not all the map but enough to make mine go very wrong. They then sent another which didn't work at all, then eventually I got the one that was right and now it goes like stink. I don't what I would have done with out a dealer to sort it out as RICA want nothing to do with the customer direct.
    I haven't driven the car for a while but took it out late last week to test the new filter and its running really well. I was even happy with the suspension, but I was giving it some along very nice smooth A roads.
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
  6. #5
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    That's interesting then. When I took my car to the local Volvo specialist, he said that I had the 'wrong' throttle module (ETM) software installed. If I recall, I think he said it was the software for a C70 2.0 LPT, not for a V70. I fed this info back to Russ, I wonder if he chased this up with RICA and found a ££££-up somewhere...
    Anyway, mine is performing fantastic at the moment with the new map, so I'm chuffed aswell.
    All credit to Russ then, and it looks like RICA really need to get their version control sorted out...
    Chris
    Visit my Rant
  7. #6
    mikouk's Avatar
    Jul 2008
    212
    Sounds like it mate. I can't remember exactly what Russ said but that sounds along the right lines. RICA are very lucky they've got dealers that can spot their ££££ ups.
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
  8. The Following User Says Thank You to mikouk For This Useful Post:
    cornclose (Monday 27th July 2009)
  9. #7
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    I wonder if Russ is reading. Can you shed any light on this Russ ? I'm genuinely interested!
    Chris
    Visit my Rant
  10. #8
    thebadger's Avatar
    Jun 2005
    Glasgow area...
    226
    The filter can make a difference, BSR do a cone filter with a heat sheild & a socket for the OEM air pipe.
    K&N do their cone & panel filter, which will aid performance.
    Other than that, there are induction kits like pipecross etc (the money heads very far north at this point) which come with cold air pipes which you need to rig & fit yourself.
    The "cone" type filter gives a louder suction noise, which sounds meaty.
    The "panel" type filter is more subtle, but can offer "some" bigger improvements in power as unlike the cone filter it only gets cool air.
    I hear angry typing as I post that one... (hot air does not improve the performance of the engine vs cool air. Lots of ppl on here disagree, I have a panel filter as I like the stock look. tho it is a K&N!)
    You think I know **** nothing! But let me tell you I know **** all!
  11. #9
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Hi
    You can also get a variety of other Remaps - my personal recommendation is from HLM in Bromsgrove- they have a new tuning tool from Sweden. It cheaper and better than the PPC.
    http://www.hlmtuning.co.uk/news.html
    As far as panel filters go - there isnt much in it, IMHO
    Volvo ABS ECU Repair
  12. #10
    mikouk's Avatar
    Jul 2008
    212
    Whys that better then? More power?
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
  13. #11
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    If it's cheaper than a PPC (which I think is a little on the expensive side if I'm honest...) and it does the same job, i.e. delivers a map into the car's ECU, then it's certainly worth investigation.
    However, it's the map that counts IMO, and despite the little issues I had originally, I think the map is superb for my needs!
    Chris
    Visit my Rant
  14. #12
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    RICA PPC is 1 map and is basically just a loader. The ECM tuning system give you more flexibility - it's laptop based.
    I don't remember if PPC actually does fault code reading??
    You can tune upto 5 cars - so in theory you could all get together and buy 1 map each (but don't tell Hamish I said that)
    As for power - I have been very impressed with the results seen so far (admittedly on ME9 engines). I am getting a tune from them when I get back. So I will keep you posted.
    For me it is the single most interesting development in ME7 maps for sometime
  15. #13
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    The PPC does do fault code reading. I havn't tried it though - I use my laptop for that!
    Chris
    Visit my Rant
  16. #14
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Precisely - so going forward (something I like to do a lot) - I'd say the geek in me would want something on my Laptop to do the whole job?? Plus it gives me an excuse to buy another laptop - which will keep Justin happy.
    Back to the thread title topic - You can also buy filters on line direct from
    http://www.hlmtuning.co.uk/acatalog/...r_Filters.html
    Which is odd because the online shop at HLM has been empty for a long time.
  17. #15
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    If this had been readily available when I got my PPC, and was around the same price (or less) then it would have been on my list for consideration, that's for sure...
    Chris
    Visit my Rant
