Results 1 to 12 of 12
Thread: Throttle Body
    Junior Member
    Jul 2009
    0
    Throttle Body
    Hi all,
    Had an account on here a while ago, and had to resign up it seems.
    got a little bit of a problem
    Car :
    S60 T5, 2001 reg (2002 spec car accoridng to the vin number being entered at a volvo dealer, was bought late 2001 so was 2002 spec?)
    Symptoms :
    When the car turns on, idles roughtly, jumps up and down a bit on rpm, sometimes will cut out. when its first started it is likely to stall If I drive to a junction and put the clutch in, after a minute warmup its fine.
    Cause(As told by my garage):
    Breather on the engine was leaking, fouled the MAF sesnor, and the throttle body.
    Fix (As told by my garage)
    Have replaced the breather and MAF. Throttle body needs a software ugprade, but to do this, I need a new throttle body, and it has to be fitted by a volvo dealer or they won't do it. Estimated 500 quid.
    Now I was wondering if I can jsut take the throttle body out and clean it down?
    I have done a search round and found some links that give the idea you can....
    http://answers.yahoo.com/question/in...0172117AAC6rni
    http://www.matthewsvolvosite.com/for...pic.php?t=4442
    The first one above, talks you through taking the hose of spraying some liquid in, then starting the engine and running it, which cleans the throttle body, but says 'If the check engine light' isn't on.#
    Which mine is....
    Any suggestions advice would be appriciated, as can't really afford the 500quid at the moment, only do about30-50 miles a week.
    Have been told it won't damage the engine, just will get worse over time?
    w01fy
    thebadger's Avatar
    Jun 2005
    Glasgow area...
    226
    The throttle is an ETM (electronic throttle module) & is probably the best known fault on these cars.
    I had my ETM cleaned & the software updated *Gratis*!
    Volvo know about the problem & as such, will try & fix it.
    Contact yer local stealers & ask what they can do for you, explaining the issue & that the throttle has not been responding & that you have "hunt" at idle.
    They usually ask to have it in & do a full clean & reprogramme for nowt, but advise of the cost for a replacement (which is actually about £267 IIRC) which has been dropped in price due to the Italian peice of tat that was fitted as standard failing on virtually every car that has been disgraced with it's offencive existence!
    Call volvo & go down the right path to getting it sorted. The softwear upgrade is not something that can be done yourself anyway.
    HTH
    You think I know **** nothing! But let me tell you I know **** all!
    Jul 2008
    38
    Volvo no longer offer the free clean & upgrade they just do the replacement. You can save part of the cost of the upgrade (which as Badger says is between £250 & £300) by doing the physical installation of the ETM yourself, but the car will be in limp mode until the dealer does the software update.
    thebadger's Avatar
    Jun 2005
    Glasgow area...
    226
    I'm sure if you lay it on thick with a trowel, "oh my car keeps cutting out at junctions & roundabouts" type talk, they should still sort it for nowt, but I guess it depends on the stealer!
  5. #5
    Suspended
    Jul 2008
    In the Scottish boonies,at the bottom of a pint tumbler..
    92
    Exclamation
    ETM.......Eternally Testing My patience. Thanks Ford!! Thank goodness mine was built before those b******s took control.
  6. #6
    thebadger's Avatar
    Jun 2005
    Glasgow area...
    226
    Aye, but they're stealing all the T5's to put in chav-tastic coloured focuses!
    Bam-pots!
  7. #7
    princepugh's Avatar
    Oct 2006
    South Yorkshire
    70
    There's plenty of discussion on here re the ETM but if your primary symptom is erratic idle, cleaning the butterfly valve WILL help and will probably sort the idle (if your MAF is good).
    Any local workshop or Indie should be able to clean it for you and that might get you out of jail for a bit but the unit is destined to fail at some point.
    As those articles note, apparently it's a bit difficult to get to also.
    Hope that helps
    Princepugh
    V70 T5 P2
  8. #8
    Junior Member
    Jul 2009
    0
    cheers guys, appriciate all your time replacing
    Will have a look at how much hassle it is to get the thing out and clean, anyone give me an idea on that, not an expert mechanic, but changed breaks/discs in the past, couple of CV joints, that covers my mechanical skills
    If that helps so be it, otherwise Volvo it is, when did they drop the cost?
    thanks
    w01fy
  9. #9
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    Wink
    Quote Originally Posted by w01fy View Post
    LINKY
    Oops. Linked to t5d5.org. Is that allowed ?
    Chris
    2010 Alfa Romeo 159 JTDm
    2001 V70 T5 SE (RICA 310)
    1997 9000 Aero (Abbotted)
    Visit my Rant
  10. The Following User Says Thank You to cornclose For This Useful Post:
    Happygilmore78 (Friday 17th July 2009)
  11. #10
    thebadger's Avatar
    Jun 2005
    Glasgow area...
    226
    Yes Chris, you are now in the website love-rat corner! I can hear some moderators discussing how many portions of humble pie you shall be force-fed!
    For shame on you!
    Anyhows, t5d5's format is pretty piss poor.
    It has no "how to" with photos, which I'm sure there is in the (wait for it) how to section!
  12. The Following User Says Thank You to thebadger For This Useful Post:
    cornclose (Thursday 16th July 2009)
  13. #11
    Junior Member
    Jul 2009
    0
    hi
    cheers for the link, does seem not to bad, will have to find if there are some photos round, just so i know im unpluging the right thing
    cheers!
    W01fy
  14. #12
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    hi
    cheers!
    W01fy
    LINKY
    Chris
    Visit my Rant
