Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: 1200 rpm
  1. #21
    Some people hate to see you
    doing well. They are losers...
    PaulZX's Avatar
    Jan 2009
    Skegvegas
    542
    could be as simple as the butterfly not closing properly. I'd check the control arm on the throttle housing, is free and not fouling on anything at all before I spent any money on it.
  2. The Following User Says Thank You to PaulZX For This Useful Post:
    ikp_77 (Saturday 18th July 2009)
  3. #22
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Where are you from? A fresh pair of eyes may be able to pick up any problems you may have missed if you are local to any helpful members. Split hoses are common especially around where the hose clamps are tightened against the hose as they can appear to be fine until the clamp is tightened. Check hoses completely along the entire hose when removed to make sure then tighten them back up properly afterwards. Its worth doing a pressure test on the inlet system to find or eliminate the risk of leaks. I had a split hose appear on saturday and my revs were in a similar postion to yours. My split hose was to the evap purge valve.
  4. The Following User Says Thank You to Alan M For This Useful Post:
  5. #23
    Niles's Avatar
    Jan 2006
    On the Verge
    470
    it may just be a simple case of the throttle cable is wound up to tight & is lifting the butterfly. try disconnecting the throttle cable then start the car. Maybe that. Worth the 5 mins to do it.
  6. The Following User Says Thank You to Niles For This Useful Post:
  7. #24
    Jul 2008
    59
    sorry for being thick but wots ecc mate cheers
  8. #25
    Jul 2008
    59
    what is the ecc mate
  9. #26
    Suspended
    Jul 2008
    In the Scottish boonies,at the bottom of a pint tumbler..
    92
    Talking
    Electronic climate control buddy. When the compressor is engaged, the ecu compensates for the extra load.
  10. The Following User Says Thank You to AlanG For This Useful Post:
  11. #27
    Jul 2008
    59
    that sounds like it would need to go to a auto sparky and could be expensive
  12. #28
    Suspended
    Jul 2008
    92
    Smile
    Not necessarily my friend. Rule out all the usual suspects first. I know I've said it before but vacuum leaks are these cars bugbear. Once that is done,ICV. Trottle tubes get gunged up. You'll get there mate.
  13. The Following User Says Thank You to AlanG For This Useful Post:
  14. #29
    Jul 2008
    59
    got a idle control valve today of ebay 13 pounds to the door am going to put it on her tomo so i can rule that out and thanks again for all your help
  15. #30
    Suspended
    Jul 2008
    92
    Good job matey. Did well for that money and let us know the result.
  16. #31
    Jul 2008
    59
    put the idle controll valve today and it was just the fast tick over so i was sick when that did,nt work i had a bit mess about with that little ecrew thing and ajusted the arm and its ticking over ok now at 900rpm boosting ok aswell ave missed driving her good to haver her back thanks again
  17. #32
    Jul 2008
    59
    well it was boosting ok its down on power and when its boosting up its lumpy not smooth like it used to be
