Results 1 to 6 of 6
    Junior Member
    Jun 2009
    Guildford
    2
    V70 Front suspension noise.
    Hi,
    I have and odd noise coming from passenger side, sounds a little like a worn bush or ball joint.
    Only happens when turning right at approx 3/4 steering lock at fairly slow speed.
    Took wheel off, could not find any play. Removed anti-roll bar tie rod and that was OK.
    Any suggestions would be welcome.
    Regards
    Brian
    Jul 2008
    111
    Is it a constant clicking noise if so it sounds like a shot CV joint
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Could also be top-mount/suspension strut bearing
    Volvo ABS ECU Repair
    Jul 2008
    0
    My steering bump stops dry out and get quite noisy as I approach full lock. Sounds hideous at times (grinding/metallic sound) but quiet again once greased.
    2005 (163) V70 D5 SE Premium Pack 130k. 10" sub/Fli amp with Grom audio kit. Shark stage 1 with EGR delete and 320mm discs. Enjoying the comfort and (relative) economy.
  5. #5
    volvoturboman's Avatar
    Apr 2009
    Londonderry, Northern Ireland
    158
    My first thought if tie bar and bushes are fine would be the C.v. joint as mentioned earlier, however if its not a clicking noise probably top suspension mount. Someone on here is I'd say right
    As the T5 came to a lonesome end
    Its just the V70 2.5 10 valve SE, pictured here with the 2 people that make life worth living, my babies.
    Needs a wash Image taken in the beautiful Malin head, Irelands most northerly point.
  6. #6
    Junior Member
    Jun 2009
    Guildford
    2
    Many thanks for the replies.
    Its not a constant clicking, more like a wobbly slight clonking noise on 3/4 lock.
    Sounds are very difficult to describe.
    Could be top mount, CV joint or something else.
    Will monitor the problem and advise.
    Regards
    Brian
