I want to connect my c70(me7) to my laptop, anyone recommend a cabel off eBay that will work?
Someone techy must be out there?!
ive been looking in to this aswell & would like to here some other opinions, but ill gladly tell you what ive learnt so far wich aint a lot.
it all depends on what you want it for if its only fault diagnostics on the Volvo a PPC stand alone unit it the daddy but only does Volvo cost around £120 reads all the codes from allover the car.
an elm scan 5 dose multiple cars but will only read the engine diagnostics cost around £140 with software & runs on a pc
there are remapping units for the same cost but ive not looked at these yet
or you can have one that dose all the above but costs thousands of pounds.
well that a bout as much as i know about OBDII & it may not be correct i hope some one corrects me if im wrong.
Dan
check out this one, says for 2001+ cars only, but works with some/most functions on mine which is a MY1996 (motronic 4.4 ecu and later which usually means V/S70 onwards) and theres other software available on the net to download
http://www.gendan.co.uk/product_ELM327.html
I use Proscan software with it as I found that to be the one that performed better
The MTE softloader does diagnostics and data-logging on the ME7 cars, including the C70.
Still looking to get one of these cables, would a USB one be ok?
Anyone? I know some of you have done it.
