Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: 41.5 mpg
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    41.5 mpg
    Went a round trip from Oldham - Blackpool today
    A Round trip of 110 miles.
    Cruising at 65 - 70 mph my average mpg shown 41.5mpg
    For a car that weighs nearly a tonne and a half and cruising at motorway speeds thats unreal.
    Long live the 304'D T5
    Suspended
    Jul 2008
    In the Scottish boonies,at the bottom of a pint tumbler..
    92
    Exclamation
    That just doesn't sound possible buddy.....Not doubting your word but is your info centre doofry taking drugs????
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Im sure my average mpg is totally wrong it never goes above 23mpg but when i work it out with how much fuel ive used to how many miles i do i get quite good mpg so god know
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Try it for yourself matey
    Nothing wrong with the info center on my car.
    Cruise at 65 - 70 mpg for 40 miles and see what it shows i think you will be pleasently surprised
    Dont get me wrong after i went to Bolton and back but i was giving it some and even at 70 + i was still getting 29 + mpg
  5. #5
    Suspended
    Jul 2008
    92
    Talking
    Can't beata Rica! Good to hear,wi a bit o luck I'll get a decent run in mine soon. Normally averages 33-35mpg but short runs
  6. The Following User Says Thank You to AlanG For This Useful Post:
    cameron (Monday 25th May 2009)
  7. #6
    May 2006
    Cheadle Hulme
    137
    Lee,
    May be worth checking your speedo trip against a measured mile. I know mine is not accurate, and therefore don't really believe what my info centre tells me with regard to fuel consumption.
    Pookie
  8. #7
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by pookie View Post
    speedo's are programmed to have an error, i know on newer Volvo's there is a secret menu to display the correct speed which from what i've seen is spot on (it will be wrong if running non-original tyre sizes tho) & would of thought the info/trip computers use the correct figure to work everything out
  9. #8
    May 2006
    Cheadle Hulme
    137
    Quote Originally Posted by p fandango View Post
    I can't understand ( as an motor engineer ) how it can do this, other than a G.P.S. link-up. The newer cars may have this but the older 850's I very much doubt it.
    Pookie
  10. #9
    p fandango's Avatar
    Aug 2004
    4,216
    the whole speedo system is still electric instead of the old cable drive, what i'm saying is the system actually measures a more accurate speed than it displays so would of thought the trip computer would use that figure. The 850's are more than capable of this sort of stuff & have some very trick electronics in there (like the rev-counter using a 4cylinder pulse instead of a 5cylinder one)
  11. #10
    Feb 2006
    7
    Get your afr's checked
    I did gloucester to plymouth and back 400 odd miles and got 34mpg
  12. #11
    polredt5's Avatar
    Jul 2008
    The Isle of Lewis
    10
    I did 415miles on saturday and i managed 28.3 avg.That was with two sticky calipers though,guessing low 30s if all had been well.
  13. #12
    Nov 2006
    planet earth
    14
    most electronic speedo's read the pusles from the ABS, so if tyre size is correct speed can be measured almost exactly. If you read speed from your OBD2 port, and put in wheel size, and tyre size it will read almost perfect correct speed, with a tolerance of fractions of a percent in a straight line
  14. #13
    May 2006
    Cheadle Hulme
    137
    Quote Originally Posted by cookie View Post
    Now I understand that. Can this be done on the old 850's? There is so much diversity in wheel and tyre sizes it would be useful to know.
    Pookie
  15. #14
    T5arrrgghh's Avatar
    Mar 2009
    Aberdeen
    15
    wow if i get 28 i have been driving like a saint! i get 20 on the runs to the forest for biking at the moment! ah well. and as for the speed thing i have tried and checked it against a few sources and its all out but then i am on 40 profiles but the average speed seems a bit more accurate than the dash indicator, but hey they are just indications!!
    1996 850 T5r, RICA 304, samco radiator, vac lines and boost hoses, powerflex bushes on wishbones and top engine mount, cross drilled and grooved discs, HID's, V70 rear lights, K&N panel in slightly drilled box, powerflex anti roll bar bushes, xc90 spring mounts stage 0, 200,300 miles
  16. #15
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Used my sat nav today to judge the speed and there was a difference of 4 - 5mph
    If thats right then i was only doing 60 - 65mph and not the stated 65 -70mph, so maybe thats where the higher mpg has come from
  17. #16
    850 2.5 10v's Avatar
    Jul 2008
    186
    Brim the fuel tank until its so full you can see the fuel.
    Drive 100 miles and then brim it again.
    Record the number of litres used to re-fill.
    Do the maths and you'll know for sure what mpg you are doing.
    Cheers
    Volvo 855 2.5 10v CD
    Its got everything except a turbo - boo hoo...
  18. #17
    flyingbrick's Avatar
    Sep 2008
    Port sunlight , Merseyside.
    493
    Quote Originally Posted by cameron View Post
    Hi Lee.
    It will be because you have put 17" wheels on buddy.....
    the speedo will be out by like you said between 5 mph and 8 mph....
    Cheers Mark..........
    EBC DRILLED GROOVED DISCS. EBC GREEN STUFF PADS. AIR CON REMOVED. TWIN EXIT EXHAUST. BLACK MESH GRILLE.GREEN PAPER AIR FILTER. FRONT SPLITTER. POLY TOP BUSH.V70 REAR LAMPS
    The greatest trick the Devil ever pulled was convincing the world he didn't exist
    http://www.r2rc.co.uk/landing/index.htm
  19. #18
    p fandango's Avatar
    Aug 2004
    4,216
    speedo's by law can read upto 10% under (never over) & tbh have never known any car/make to read spot on.
    My 850 (on 18's) reads 5mph out across the whole range, while my S60 (on standard wheels/tyres) reads 7mph out
    as i've said before i suspect the fual computer would use the acurate MPH figure & not from the speedo
  20. #19
    Jul 2008
    2,869
    I think it's great that your getting those fuel efficency readings from your car Cameron. My brother achieved similar figures with his S70R on a similar run. However hasn't acheived those figures since he had his injectors cleaned and two were found to be faulty. The reason for his optimistic fuel consumption reading was the engine was running lean as a result of the two faulty fuel injectors, the standard lambda control can only monitor afr across the 5 cylinders not at each cylinder at any given time and will then adjust all to suit, running lean isn't ever good for an engine especially an engine utilising forced induction.
    If I were you I would get the AFR's checked and the I would certainly advise you get the fuel injectors cleaned/flow checked.
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  21. #20
    gtiteen's Avatar
    Jan 2006
    Eastbourne, East Sussex (home) and Southampton (uni)
    34
    i have had a trip computer reading of 38 on a trip from eastourne to gatwick in my old rica 304 850 on standard rims. Was deliberately trying to dive economically. I imagine there is some innaccuract but still reckon must have been 36 odd which i was happy with. well compared to my current 18mpg lol.
    1995 854 T5 (upsoloute ecu, koni's etc) sold
    1995 855 T5 (rica 304 and lots of other bits) sold
    1994 Subaru Impreza WRX STi v1
    1995 Clio 1.8 RSi (hoping to swap for a t5 at some point)
