Had a look at my cooler other night an the inside has residue of oil... is there anyway i can clean the cooler out so its all sparkly fresh haha?!?!
thanks guys
thanks guys
Past
95 854 2.5 10v with b5254t conversion...RIP,
96 850 awd...cut up RIP,
95 965 manual!..parted out,
94 855 T5 green..scrapped RIP,
94 855 T5 red..heart lives on body RIP,
03 S60 D5 sold
94 855 glt 2.5 10v white parted out RIP
97 V70 AWD parted out RIP
Present
93 854glt 2.5 20v (turbo)white daily project
04 s60 D5 (literal twin of previous s60)
You can clean it out by removing it and filling it with a good degreaser or petrol and then giving it good shake and emptying it. You can do this a couple of times then leaveit filled overnight to remove any stubborn deposits.
may give that a go now.. i though about that but wasnt sure with puttin any liquids in it for replacment back into engine
Past
03 S60 D5 sold
Present
brake cleaner works well to, but you MUST let it dry out over night or else you will have some very interesting popping noises when you start up, used to do this quite regular on my landy.
sorted it now. but thanks for the info guys,...took it into the shower filled it wit gunk an shook it about a bit..then ran the shower hose thru it till was jus clear water... an i forgot weve got a wet/dry vac/blow machine so i jus used that on the blow setting an made sure it was dry. looks like new now also so bonus
Past
03 S60 D5 sold
Present
did you do this while the mrs was out? holy **** you would have seen the mushroom cloud in germany if i had done that!! good on ya!
1996 850 T5r, RICA 304, samco radiator, vac lines and boost hoses, powerflex bushes on wishbones and top engine mount, cross drilled and grooved discs, HID's, V70 rear lights, K&N panel in slightly drilled box, powerflex anti roll bar bushes, xc90 spring mounts stage 0, 200,300 miles
Past
03 S60 D5 sold
Present
