Results 1 to 3 of 3
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    99> Upper Poly Engine Mount how to
    Well, seeing as I cant post in "How to" I thought Id post this here.
    First, remove the bolt from the upper engine mount
    Lift the arm out of the way, and using an old big screwdriver or similar, twist out the old rubber, then slide the driver down the back of the mount outer casing, and bend and lever that out too.
    Then, undo all of the Torx Screws on the cam cover, and lift away. This is to expose the last bolt on the engine mount bracket
    Then undo the four bolt that hold the bracket in place
    Lift out the bracket, fit the new bush (mine just slid in, no grease required) and then lift up the bulkhead bracket, and slide the mount under it and bolt it back onto the engine. Refit the cam cover, put the torx screws in, and there ya go
    EASY!
    Thankyou, Goodnight....much love
  2. The Following 2 Users Say Thank You to Liddo For This Useful Post:
    Barcelona joe (Friday 20th August 2010),BigJC (Monday 1st February 2010)
  3. #2
    simpT5's Avatar
    Jan 2009
    cheshire
    63
    I fitted mine in exactly the same way too, 20 min job, dead easy!
    Doesn't it sound lovely too? Or I should say, doesn't the increased sound into the cabin sound lovely, especially from about 1500 - 3500 rpm?
    Best £25 I ever spent!
  4. #3
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by simpT5 View Post
    I initially tried the old way off fitting it. Remove the bolt and lift the arm up, popped the bush in, only to find the arm wouldnt go back over the bush
    Ive not noticed any "vibration" as some people say, and I havent give her any stick, as i only live 3 miles from work, so she wasnt warmed up, BUT, i CAN tell a difference already in noise, and it sounds Luurrrrrrvely
    Who needs an induction kit
