Results 1 to 15 of 15
    Aug 2008
    rotherham s.yorkshire
    231
    ive got problems
    only 3 at the moment.
    blue smoke, oil from the MBC, oil blowing from the DV, knackered turbo???
    car runs flat until 4K revs in all gears then picks up, i think its electrical, any ideas???
    NSF anti roll bar drop link snapped off, i can sort that one...
    1991 retro alfa romeo 75
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    ER..........sounds like the turbo to me, but I'm only guessing. Your not having much luck lately are you?.
    Previous cars:
    Aug 2008
    231
    Quote Originally Posted by Tomcat View Post
    i,m not too bothered (yet) its still running fine and not using much oil strangely.
    any ideas on the electrical/sensor thing? airflow meter, lambda or something?
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    I'd say it could be the Lambda, it's probably over fueling, can you get the codes read?, that'll give you a better idea of where to start.
    Previous cars:
  5. The Following User Says Thank You to Tomcat For This Useful Post:
    nathT5 (Saturday 21st March 2009)
  6. #5
    Jul 2008
    111
    Sounds like your turbos shot nath , sounds like the oil thats burning is screwing with your emissions and confusing the ecu on your fuelling ratios .
  7. The Following User Says Thank You to MrMopp For This Useful Post:
  8. #6
    888dee's Avatar
    Jan 2009
    Dundee
    9
    aw poo mate, bit of a downer mate, hope it's repairable without to much of a pain in the wallet
  9. The Following User Says Thank You to 888dee For This Useful Post:
  10. #7
    Aug 2008
    231
    just been to fill up and now the running problem seems to have gone.
    i remember its done this quite alot when the tanks been low.
    it must be some sort of fuel starvation when the g-force sends the fuel to the back.
    need to fill up more often
    btw, the tempremental fuel cap lock made me look a right DIV again at the garage.
  11. #8
    james's Avatar
    Oct 2008
    sheffield,south yorkshire
    202
    hi nath u can buy the part to fix the locking mechanism on fuel cap you can get one for about a tenner on ebay.i changed mine but luckily for me mine stopped working and was allways left open which i got a locking petrol cap for because in the past somebody put diesel in my mr2 when the mechanism went on that. anways its a bit of a drag to get to it. the boot back trim needs to come off and the rear seats if you have them and the right interior panel as you look in the car needs to be removed and all will be revealed.be carefull when removing the plastics from around the boot.if you have propper trim removers use them , best regards james
  12. The Following User Says Thank You to james For This Useful Post:
  13. #9
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    Have you got the ARB fixed yet?
    as i have one here from a V70 T5 if it is the same,
    Gary
  14. #10
    Aug 2008
    231
    Quote Originally Posted by siamblue View Post
    Gary
    no i havent looked around for one as yet.
    if it is the same, is it new and how much do you want for it with postage?
    anyone know if a v70 and 850 share these parts?
  15. #11
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    They will be the same, IIRC the V70 one is thicker so stronger, it is still on the car so will have to check the condition of it first, pm me to remind me if i don't get back to you
    Gary
  16. The Following User Says Thank You to siamblue For This Useful Post:
    nathT5 (Sunday 22nd March 2009)
  17. #12
    Feb 2005
    Somewhere in the south
    36
    Blue smoke is oil, brown or black smoke is overfuelling, white smoke is the dreaded water.....
    A 2001 Buell X1 Lightning now in sunny Tenerife and a Santa Cruz Superlight..yes I will get on it!
    Looking for a Honda Hornet CB600FS (fairing one in Blue) for the UK
  18. #13
    Aug 2008
    231
    Quote Originally Posted by Babybadger View Post
    i think tomcat was refering to the running rough up to 4K problem, not the smoke.
    this is now sorted by filling up, only does it when the tanks below 1/4.
    where,s the fuel pick-up pipe, is it located at the front?
    its as though the fuel goes to the back when booted and it gets starvation.
    does,nt do do it when taking it easy.
  19. #14
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    White smoke from the exhaust can also denote a turbo oil seal failure with unburnt oil entering the exhaust system and burning off due to the heat in the exhaust, creating white smoke.
  20. #15
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Take the inlet pipe off and feel for play in the shaft, gives you an idea of things. To be honest though i would worry about a little bit of oil, you have to expect a small amount and anyway it will atleast keep your D/V from seizing up
