Results 1 to 17 of 17
    Member
    robertbarryz250's Avatar
    Feb 2009
    hull east yorkshire
    9
    *****help bosch green injectors***
    alryt lads found my new head n got it fitted just need a set of green bosch injectors if any1 has any give us a shout cheers
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Don't R's run either orange's on auto's or white's on manuel's?
    I have a set of oranges that i was told were flowed/cleaned and never used, £25?
    If in doubt thrash it and see
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    HEad ? Head? What head? do tell more - why you did it and what you are putting on? how long did it take/cost??
    CHeers
    Woz
    Member
    Feb 2009
    hull east yorkshire
    9
    i put a volvo s70 t5 head on coz myn blew across the water jacket,yeh myn runs on a set of oranges but iv fitted a new larger intercooler,filter, full system and reverse intercooler pipe and iv been advised by a rica tuner in doncaster it would be best to fit green bosch injectors
  5. #5
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Quote Originally Posted by robertbarryz250 View Post
    Thts not necessarily true. Dependant on the level of tune and turbo you can run the oranges with a Rica but the whites or blues would give a little more scope for tuning. The greens are a lot bigger than the oranges and flow around 100cc/min@3bar more fuel on top of what the oranges flow. The whites and blues flow around 40cc/min@3bar more than the oranges.
    http://www.injectorcleaning.co.uk/flow.htm
    This link will show you the book flow rates @3bar for bosch injectors.
  6. The Following User Says Thank You to Alan M For This Useful Post:
    robertbarryz250 (Wednesday 11th March 2009)
  7. #6
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    White's would be more than capable for that spec, make sure your supplied with a map suitable to run with whatever injectors you decide to use.
  8. #7
    Member
    Feb 2009
    hull east yorkshire
    9
    i seem to be able to find plenty of blues(275cc) but cnt find any whites (175cc) if any1 spots any post me a link please....rob
  9. #8
    D'Management
    Chad's Avatar
    Jul 2008
    Birmingham
    837
    i got a set of blues and Nads has quite a few sets of whites. ring him on 07961505315
    hth
    chad
    V70R, Saffron, RICA340
    Independent Volvo Specialist
    RICA Authorised Distributor (www.rica-uk.com)
    Shark Performance Authorised Distributor (http://www.sharkperformance.co.uk/)
    www.grnmotors.co.uk (site under construction)
    info@grnmotors.co.uk
  10. The Following User Says Thank You to Chad For This Useful Post:
  11. #9
    Trader
    Aug 2005
    coalville
    68
    Blues off a T5 are about 398cc and Whites are about 350cc.
    Volvoised and S70Chris both have Whites for sale, with your mods you would probably get the lamda light come on with Greens.
  12. #10
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Are you running a 15g robert?
  13. #11
    Some people hate to see you
    doing well. They are losers...
    PaulZX's Avatar
    Jan 2009
    Skegvegas
    542
    I've been reading up on this today, an as far as I can see, the injectors flow at the rates below....
    orange ~ 315cc/min injectors
    white injectors ~ 350cc/min.
    blue's ~ 395cc/min injectors
    green ~ 468cc/min injectors
    Don't take that as gospel, but I've read in a few places this evening, and there is some differing of opinions, but they all state roughly the same figures, maybe + or - 5cc.
    If anyone knows for certain what the flow rates are, then now would be a good time to drop yer tuppence...
  14. #12
    Niles's Avatar
    Jan 2006
    On the Verge
    470
    orange = 350cc for sure!
    whites = 395cc for sure!!
    blues = 445cc i think
  15. #13
    Jul 2008
    38
    Quote Originally Posted by Niles View Post
    Sorry Niles, but simply put, those are wrong.
    The figures from Tim for blues and whites are correct. Fridge is right on the oranges, but the greens I think were a bit smaller, 440 or 450cc?
  16. #14
    Member
    pjay's Avatar
    Jul 2008
    preston
    2
    injectors
    why don't you try p.m jimathan he usually has some spares about, very handy to know because he always recons all he has, so whatever you pay is always cheaper because you are getting really good injectors, , cheers guys - pjay....
  17. #15
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    This is a Bosch Book value list for Bosch injectors as listed and used by the ASNU cleaning machine company/setup. Check your bosch injector number against those in the list to find out for sure what the injectors flow at a defined limit of 3bar/min.
    Oranges 0 280 150 785
    whites 0 280 155 766
    blues 0 280 155 830
    Greens 0 280 155 968
  18. The Following User Says Thank You to Alan M For This Useful Post:
    PaulZX (Sunday 22nd March 2009)
  19. #16
    PaulZX's Avatar
    Jan 2009
    Skegvegas
    542
    I had a feeling you'd chip in here... lol cheers for the chart....
  20. #17
    Big Pete's Avatar
    Nov 2008
    50
    Quote Originally Posted by Saaamon View Post
    You still got those injectors??? I've sent you a PM.
    VOLVO 854R (1996 model)
