Page 1 of 134 1231151101 ... LastLast
Results 1 to 20 of 2680
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,202
    BT's latest phase
    as i'm bored i thought i'd share the experience & bore you all with newer pics/spec of BT
    Exterior:
    T-5R front bumper with chrome mesh grill
    private registration plate reading “BIG T5R” or “BIG TOSSER”
    headlamp wipers removed & under headlight panels replaced
    RGM headlight eyebrows
    day running lights disconnected
    front fog lights removed
    LED sidelight bulbs
    front mounted IR camera
    S70 washer jets
    single windscreen wiper conversion
    quick release bonnet pins
    S70 fuel filler door
    custom TWR pinstripe decal & window graphics
    rear windows professionally tinted with medium tint
    1995 spec rear lights & inner boot panel
    passenger side front door handle de-locked
    8 x 18 Fox R4 alloy wheels with 215/35/18 tyres
    rear bumper modified for extra tailpipe
    SAAB 900 rear spoiler
    front wheel arch lining removed
    front mud guards removed
    USA spec front wing badges, replacing repeator lights
    Nordic design mesh bonnet grill
    boot re-badged as a T-5R
    Engine Spec:
    S60R exhaust manifold
    19T turbo
    Forge Motorsport recirc valve blanking plate
    Ferrita 3inch Stainless steel downpipe
    QTP exhaust cut-off valve
    polished & internally modified Volvo 960 throttle body
    3inch stainless steel reverse flow intercooler pipes
    3inch stainless steel intake pipe, including 3inch MAF sensor housing
    Apexi AVC-R boost controller
    vac hoses replaced with internally braided hoses
    7mm double silicone HT leads
    Bosch Blue coil
    TWE oil catch tank
    Powerflex top engine mount
    Powerflew wishbone bushes
    VW Vento horns
    front/slam panel centre & bottom support bar removed
    battery & airbox mounts removed
    Powerflow stainless steel exhaust back-box with twin exit (one each side)
    CCR cone filter
    Scuttle panel removed
    battery moved to boot using Nolan engineering alloy battery tray
    throttle wheel cover removed
    spark plug cover removed
    radiator under panel removed
    Volvo strut brace
    Volvo 302mm brake conversion
    Black Diamond braided brake hoses
    Volvo lowered chassis option (30mm lower)
    fan bypass switch
    under bonnet sound insulation removed
    DRE sequential shift light
    launch control (automatic with manual bypass)
    full throttle gear-change
    Pro automatic turbo timer
    upper radiator cowling removed
    under tray removed
    fuel injector rail cover removed
    EVAP system removed
    bonnet catches, cable & lever removed
    excess wiring removed from loom (including repeator lights, aircon, cruise control, headlight wipers etc)
    Interior:
    Dino leather 3 spoke steering wheel (with Momo boss)
    custom carbon fibre steering wheel centre
    Sparco twin steering wheel buttons (left button overboost, right button working launch control in race mode, wipers & screen wash in road)
    head-up-display speedometer (calibrated to GPS)
    aircraft style starter switch
    custom colour coded door trims
    gear level shortened by 1.5inches
    Race-X gearknob (colour coded & chrome
    Race-X Alloy pedal grips
    Cobra Monaco S bucket seats (passenger side on quick release mount)
    Raceland clip-in 3 point harnesses
    factory switches either removed or replaced with toggle switches
    non-turbo gauges
    radio removed
    speakers removed
    electric aerial removed
    spare wheel removed
    boot carpet & trim removed
    dashboard removed
    carpets, insulation & pillar trims removed
    roof lining removed
    centre console/arm-rest removed
    wiring removed (including heated seats, speaker wires, electric aerial, electric windows, sunroof, mirrors etc)
    Intended Jobs:
    remove door cards
    remove towbar & electrics
    remove sunroof
    remove ECU box & radiator cowling
    remove bitumen sound deadening
    remove carbon canister
    remove rear arch linings
    remove ABS
    replace windows with Perspex
    replace electric window units with manual winders
    as you can see from the interior pics i'm half way stripping everything so some of the things on the spec list aren't fitted yet
  2. The Following User Says Thank You to p fandango For This Useful Post:
    T4_Al (Thursday 27th January 2011)
  3. #2
    Niles's Avatar
    Jan 2006
    On the Verge
    470
    who's been a busy boy then? Bet it's 'nippy' when are you going to cut the roof off & have the only 854 cabriolet? lol
  4. #3
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    Oh god i dreaded opening this thread up after seeing the title mate lol but at least you havent had the angle grinder out yet
  5. #4
    p fandango's Avatar
    Aug 2004
    4,202
    Quote Originally Posted by Niles View Post
    theirs always more to be done on it
    tbh the interior has only came out since its been SORN so don't know how much difference the weight loss has made, my aim for the year is to get a 13.5 quarter mile. I'm trying to keep the outside looking standard(ish) just to really surprise people when she does come back on the road
  6. #5
    p fandango's Avatar
    Aug 2004
    4,202
    Quote Originally Posted by callyuk View Post
    theirs not much to grind away really (couple of brackets inside), but got a few plans for the hole-saw once the interior is sorted
    i can't wait till i get to work/play with your new motor mate
  7. #6
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    Lol dont think there much to do although still got the exhaust to swap over
  8. #7
    p fandango's Avatar
    Aug 2004
    4,202
    ah sorry i don't do exhausts, you got the starter switch sorted out now? (& is that boiler done yet lol)
  9. #8
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    Lol yes starter switch is done and so is the boiler you can have your drill back now
  10. #9
    p fandango's Avatar
    Aug 2004
    4,202
    glad the drill lasted lol, you able to carry on with the rest of the bathroom now then?
  11. #10
    BruceT's Avatar
    Jul 2008
    Bristol
    218
    Top car!
  12. #11
    Some people hate to see you
    doing well. They are losers...
    PaulZX's Avatar
    Jan 2009
    Skegvegas
    542
    go-go fandango...! lol she's not gonna have enough weight to give you any grip.... haha
  13. #12
    p fandango's Avatar
    Aug 2004
    4,202
    Quote Originally Posted by BruceT View Post
    Top car!
    why thank you sir
  14. #13
    p fandango's Avatar
    Aug 2004
    4,202
    Quote Originally Posted by TheFlyingFridgeMover View Post
    don't you worry, i'll have enough grip to whop your back-side on the strip matey lol
  15. The Following User Says Thank You to p fandango For This Useful Post:
    PaulZX (Friday 6th March 2009)
  16. #14
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    Quote Originally Posted by p fandango View Post
    Would have if some B*****D hadnt stole my money last month and this month bought the 2 cars so is on hold again lol
  17. #15
    PaulZX's Avatar
    Jan 2009
    Skegvegas
    542
    ...of that, kind sir, I have no doubt....
  18. The Following User Says Thank You to PaulZX For This Useful Post:
    p fandango (Friday 6th March 2009)
  19. #16
    The daRk knight
    LeeT5's Avatar
    Oct 2004
    Kent
    838
    Where does grandma sit then when you take her back home???
    I have to say...looks like you've been busy and i assume it will be a track car?? otherwise what's the point?
    The grille looks naff and i hate the wheels. Looks like you gotta lot to do. Nice colour thou. How much have you spent??
    Good luck with the build.
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ 21psi :: Custom 2.75" exhaust :: New KKK24 :: WG 5.5 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV @18psi :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: ATE super blue :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 :: LED H3 :: Atacama :: VolvoTech CFE OBD-V1 :: See garage for full mod list
  20. #17
    p fandango's Avatar
    Aug 2004
    4,202
    damn, well if you need any more tools from "Pedro's tool hire" let us know before i come down mate (& flog that bloody Seat lol)
  21. #18
    p fandango's Avatar
    Aug 2004
    4,202
    Quote Originally Posted by LeeT5 View Post
    when i had the normal interior in i did actually take my grandad for a run round the block, convinced him his 1.6 Sierra wasn't as quick as he thought it was lol
    mainly for drag runs & weekend fun but probably get a few trackdays in, one of my missions is to take it to the Nurburg Ring
    never been keen on the wheels myself tbh (there is a thread on here trying to sell them 2hrs after i got them lol), but they were reasonably priced & alot stronger to handle the potholes than my previous wheels. I keep threatening to buy some 19" BTCC rims. As for the cost last count the receipts add upto just over £10k, but thats including previous items not just current spec
    thanks
  22. #19
    p fandango's Avatar
    Aug 2004
    4,202
    been out with scales & weigh'd a few things, i'll put some more up as & when
    wiring protecton (plastic casing down the sills) 2.2kg
    wire (including towbar electrics) 5.8kg
    heater box (matrix & motor) 8.2kg
    window motors (x4, no mechanisms) 3.0kg
    total so far 19.2kg
  23. #20
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    total so far 19.2kg
    -1 P fandango 15 stone saved lol
Tags for this Thread
