Not my car but a mates. T5R manual M reg. When the cars running it idles at 800rpm very smoothly. Rev it & the revs build to 6500 no problem, however, the revs take ages to drop. Sometimes it behaves, I went out in it tonight & gave it some welly, go's really well but when at 'giving it some' the revs don't fall between gear changes & when coming to a halt allowing the engine to help with slowdown (trailing throttle) the revs still stick up around 4500-5000, then sits for a second or 2 then slowly falls.
Really annoying bit is that if you pull over & rev it while the cars standing still the revs seem to behave.
Throttle body has been cleaned & linkage isn't an issue. Can't see any air leaks & as the idle is perfect an air leak isn't really a suspect.
Turbo blows nicely.
Any ideas? The owner is getting majorly tired of it.
