Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 81
Thread: Lpt mbc
  1. #41
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    So whats this the fuel cut at 12psi?
    How do you get around it?
    Or is it something more drastic than that?
  2. #42
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Alan M View Post
    Duane have you an AFR meter gauge system fitted?
    no not yet, i've got to get bigger injectors (currently running at 99.7% injector duty) so i'll get one fitted as soon as i get some sorted
    What sort of extra cooling did you use to keep the Turbo from getting to hot?
    tbh i can't remember what spec BT had got at the time, the benefit of the reverse flow would of helped it
  3. #43
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by bomb192uk View Post
    no totally standard, when i first fitted the MBC it ran well at 15psi but i didn't realise i'd got a split vac pipe. When i replaced it she boosted to 20
    i don't recommend anyone try going anywhere near that high, 13psi is considered a safe limit
  4. #44
    New Identity
    Dec 2006
    West Midlands
    2,491
    Anyone know how the ecu knows its at 12psi? Or is it the knock sensors that trigger the fuel cut?
  5. #45
    Oct 2008
    0
    ECU calculates boost pressure from throttle position and air temp sensor and MAF reading.
  6. #46
    New Identity
    Dec 2006
    West Midlands
    2,491
    So is the fuel cut bad for the engine?
  7. #47
    p fandango's Avatar
    Aug 2004
    4,216
    its there to protect your engine so not exactly bad, but once you've hit it you'll know how aggressive it is & won't want to hit it constantly for your own pleasure. Mine was set so close that any excess load would cause it to cut in, if i wanted to floor it i had to throw it down 2 gears
    boost cut is normally around 15psi
  8. #48
    Jod T5's Avatar
    Oct 2005
    Near Chelmsford Essex
    5
    Quote Originally Posted by timbo_1975 View Post
    Actually the ECM does not calculate boost pressure but i accept the ignition will cut due to knock and Maf sensor inputs....There is no air temp, other than the input temp (maf) on the 850, the 70's are different....
    Cheers
    Jod
    855 rica 304bhp, Adjusted Wastegate, Bleed Valve, ITG Panel Filter, 171k fsh, Volvo Strutt Brace, Polybush Topmount , 4mm Samco Vacuum Hoses, 10 Core "Racing" Ht Leads, 302mm Volvo Discs under 16" Columba Alloys, Performance DS2500 Fronts Red Stuff Rears, Drillled Airbox, 5w/40 Oil Changed @ 5k intervals,
    764 B230ET 108k FVSH No mods yet...Planning underway.....
    Dum Spiro Spero
    VOC 850/70 Register Keeper
    VOC 20419
  9. #49
    Jod T5's Avatar
    Oct 2005
    5
    Quote Originally Posted by p fandango View Post
    i ran mine at 20.8psi
    Hey Duane...
    Currently i am getting a compitant 19 psi using the back of a Rica with a MBC (yes all those years you have been on at me)....Not a hint of cut, strong but quick boost....AFR is good..I expect there is a little to play with...Running 15g and stock zorst too...
    Best
    Jod
    Dum Spiro Spero
    VOC 20419
  10. #50
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Jod T5 View Post
    Hey Duane...
    Hi Mate, hows things?
    well what can i say, MBC is the way to go lol. Always looks good seeing the needle go off the clock, i haven't tried it with the speedo yet tho lol. Have managed to find the higher boost cut off the ECU yet, just interested how much higher it is than standard? Are T-5's dar to run or what, i notice neither of us have got any fuel lol
    take it easy mate
  11. #51
    Jod T5's Avatar
    Oct 2005
    5
    Hi Mate, hows things? well what can i say, MBC is the way to go lol. Always looks good seeing the needle go off the clock, i haven't tried it with the speedo yet tho lol. Have managed to find the higher boost cut off the ECU yet, just interested how much higher it is than standard? Are T-5's dar to run or what, i notice neither of us have got any fuel lol take it easy mate
    Hi Duane...
    The car was supposed to run a pressure of 9.x psi, which allegedly crept up to around the halfway mark on the instument panel dial....I never owned a new one so i cant collabourate this, however alot of the 850 i have found myself involed
    with are only producing around 6psi which is really only about a third of the scale in my experience...The reasons for this are more likely to be down to bolt ons rather than the engine itself....
    I like to keep the tank empty as i am working on a less weight/more speed theory..lol
    I would expect that a stock car would be able to make 10psi with a peak to 13 without hitting ignition cut....
    Best
    Jod
    Dum Spiro Spero
    VOC 20419
  12. #52
    Oct 2008
    0
    Cheers
    Jod
    I was refering to ambient air temp sensor. - i am aware the 70's use the sensor mounted in the front bumper, and the 850's the one within the MAF.
    And yes, the ECU does derive boost pressure- thats how it knows how much to modulate the BCS according to its look-up tables.
  13. #53
    Jod T5's Avatar
    Oct 2005
    5
    Yes that is correct, it can derive pressure from its sensors, however it can not read direct boost pressure, which i guess you know already....
    Cheers
    Jod
    Dum Spiro Spero
    VOC 20419
  14. #54
    Oct 2008
    0
    Indeed, which is why i said "the ecu calculates boost pressure from..." !
  15. #55
    New Identity
    Dec 2006
    West Midlands
    2,491
    Just an Update....
    Had to move the mbc from its position on the upper engine mount bracket, as the mbc was getting very hot with the heat from the engine, etc (not that it matters, but just in case) and adjusting it was a nightmare as it was burning my fingers. I have a strut brace, so i've relocated it on that above the abs unit (see pic) and its much cooler now.
  16. #56
    mk3phill's Avatar
    May 2006
    neath
    21
    sounds like a well worth while investment ,.. dude whats the silver box,.. catch tank??
    Past
    95 854 2.5 10v with b5254t conversion...RIP,
    96 850 awd...cut up RIP,
    95 965 manual!..parted out,
    94 855 T5 green..scrapped RIP,
    94 855 T5 red..heart lives on body RIP,
    03 S60 D5 sold
    94 855 glt 2.5 10v white parted out RIP
    97 V70 AWD parted out RIP
    Present
    93 854glt 2.5 20v (turbo)white daily project
    04 s60 D5 (literal twin of previous s60)
  17. #57
    New Identity
    Dec 2006
    West Midlands
    2,491
    yep, its actually a 'catches bloody everything' tank, as there's so much ££££e that comes out when I empty it, mostly its water and oil mix.
    I was an reading EPE magazine from November 2008, and they've got a DIY circuit that you can fit into the line between the ECU and the BCS to variably control boost via a variable resistor mounted on the dash. Basically it intercepts the signal from the ecu to the BCS and delays it a bit.
    They also had a fuel cut bypass module to build too, but it works off the input from a MAP sensor, and our cars aren't fitted with those.
  18. #58
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    Probally for the best as that fuel cut is saving you from running too much boost and bending a rod or too
  19. #59
    New Identity
    Dec 2006
    West Midlands
    2,491
    Yeah, I thought that too, its there for a reason innit. Best not to mess too much.
  20. #60
    callyuk's Avatar
    Nov 2006
    aberdare
    13
    yes indeed
