About a ltr+, basically when its cold its way over the hot mark, what damage can it cause.
Are you checking the level the proper way?.
How do i fill my auto box i think its low, the cars a bit " Jerky " from drive into Reverse.
Im not sure how to check the level in mine either
Cheers
Lee
Fill through the dip stick tube.
Don't overfill as that is worse than not quite enough
cameron (Sunday 15th February 2009)
Is it just normal 10W 40 Oil, i have S/S oil for the engine is that ok ?
Go to a dealer or email rufe as iv forgotten the name of the proper stuff.
Dont use engine oil unless you intend to change your box
I will do tomoz, in the meantime anybody know what it is ?
I can get it from work to save me a load of hassle
Lee
You will be very lucky to have it at your work.
Does this sound about right
850 (AW50-42)
DEXRON IIE OR MERCON
Thats off of the Mitchell CD i have.
Lee
to check the level on a autobox you need to have the gearbox hot. so check it after going for a drive not when cold.
gazbak1
To check the atf level do the following:
1. Get the car to normal operating temperature..
2. Move the gear selector lever through all the gear positions stopping for a few seconds in each position.
3. Return the lever to the park position and with the engine still idling wait two minutes.
4. Remove the dipstick and check the level. It should be between the MIN and MAX marks on the side of the dipstick marked HOT. The difference between the two marks is approximately 0.5 litre.
If the transmission is not hot use the side of the dipstick marked COLD
The fluid has to go in the dipstick tube but only add a smallish amount at a time AND go through the same procedure each time you add fluid.
cameron (Monday 16th February 2009)
Well what can i say, We DID have it I was surprised as well
All the times ive worked on Volvos and i never noticed the gearbox fluid dip stick
Needed about 1/2 ltr to take it to just under the HOT line.
Still jerky when going into reverse but a lot smoother gunning it from the lights
Cheers guys
Lee
When was the last time the oil was changed?.
Last year mate about October.
I had a lackie do it for me but then decided to empty it completely and put new in
Cheers for the help bud
Lee
Cheers Mark..........
EBC DRILLED GROOVED DISCS. EBC GREEN STUFF PADS. AIR CON REMOVED. TWIN EXIT EXHAUST. BLACK MESH GRILLE.GREEN PAPER AIR FILTER. FRONT SPLITTER. POLY TOP BUSH.V70 REAR LAMPS
The greatest trick the Devil ever pulled was convincing the world he didn't exist
http://www.r2rc.co.uk/landing/index.htm
It was Dextron 3 that went into it when i did the complete change but cheaper stuff when the other lad did the top up.
We have a PC database that we use for all fluids and basically anything to do with any cars, so its a handy tool to have
Cheers
Lee
Hi lee you got the springs done
No mate this week hopefully
Are you in need of the compressors, i could get them back to you we have an air powered set up i can use
Cheers bud
Lee
hi lee not in a rush at the mo but in a couple of weeks or so going to do the 240 suspension
