Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Dec 2008
    A large blue spinning semi molten rock floating in space
    11
    Recirculating valve
    whats it do? can you blank it off, why would you blank it off?
    thanks
    red 96 850 t5 rica304 K&N cone filter Bailey dump valve
    ferrita 2.5 in cat back
    "A volvo isn't made for tupperware parties"
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by zoomungus View Post
    its basically a dump valve but ditches the air back into the system instead of the atmosphere. I'm not running a recirc or dump valve on my 19t & not noticed any loss in spool up between gear changes
    Jul 2008
    Manchester (ish)
    215
    I thought the point of a recirc or a dump valve was to stop the turbine getting damaged due to back pressure when the throttle is backed off... when the fuel and air is no being put into the cylinders but you still have a lot of pressure in the system the recirc valve"depressurise's" they system so that you dont stall the turbo.
    Of course I could be talking utter ££££££££££.
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by wegal View Post
    your basically right, you've got to be running quite high boost levels to damage the turbines & as i say i've not noticed any lag between gear changes
  5. #5
    Dec 2008
    11
    so if i have a dump valve i no longer need the recirc?
  6. #6
    p fandango's Avatar
    Aug 2004
    4,216
    spot on mate
  7. #7
    Dec 2008
    11
    so i blank it off then do what with the pipe?
  8. #8
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Fit it to the dump valve.
  9. #9
    Dec 2008
    11
    just looked at the pipe, the dv pipe is teed into the recirc, can i not just disconnect the the recirc and put it direct to the dump valve, then block the end of the recirc inlet?
  10. #10
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Yes. Just pipe the DV to the nipple on the inlet manifold where the recirc goes.
  11. #11
    Jan 2009
    Dunfermline, Fife
    1
    Taking this topic and running with it... what's the best/easiest way of blanking off the recirculation valve, suspect mine might be iffy so blanking it off would eliminate that area. The turbo doesn't strike me as being very accessable on these, so safe to say it's a bit of a bitch of a job?
  12. #12
    Jul 2008
    Red Lodge
    11
    not really, boost pressure helps to hold the recuirc valve shut, disconnecting it will end up in lost boost......
    seal the bloody thing up good & proper
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=2552&dateline=1218822  313
    She may not be perfect but i love her anyway....
  13. #13
    Jul 2008
    Red Lodge
    11
    Quote Originally Posted by Turbodave View Post
    the blanking plates give you a lot more room to work than the origional valve however, its not that big a job to pull the compressor side of the turbo out of the car
  14. #14
    Dec 2008
    11
    Quote Originally Posted by PNuT View Post
    just ordering a forge blanking plate!
  15. #15
    Jan 2009
    Dunfermline, Fife
    1
    Was that sarcasm?!
    Don't supose there's a how to guide, or anybody fancy doing one... had a wee search of the forum and google but nothing that helpfull. And can I fabricate a blanking plate, or is it worth following your man there and ordering a Forge one?
    Cheers
  16. #16
    Dec 2008
    11
    if i had the time i would make one, its nothing special, just a plate
  17. #17
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Just be careful with the 3 x 10mm bolts, drop them and your stuffed
    Very fiddly to get them back in as well, a ratchet spanner is your best friend
    Good luck matey
    Lee
  18. #18
    Jul 2008
    Red Lodge
    11
    Was that sarcasm?!
    Cheers
    no, i was being serious.... but it depends on your mechanical knowledge i guess!
  19. #19
    Dec 2008
    11
    tight as a nuns chuff round that turbo!
  20. #20
    Glad im Back -D
    cameron's Avatar
    Jul 2008
    Oldham, Lancashire
    983
    Recirc on the Turbo
    Recirc off the Turbo
    Blanking plate in Place
    Just move the air filter hose out the way and get in there with a Ratchet Spanner ( 10mm iirc )
    The bottom nut is easier to get from underneath the car
    Lee
