Results 1 to 14 of 14
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Porsche Brakes - A few questions
    My question are:
    • What parts are needed?
    • How easy are the brackets to get hold of and where from?
    • Will they fit under standard 850r wheels?
    • Are there any Porsche breakers that sell the cailpers?
    Cheers..
    Saaamon
    May 2005
    Chester, UK
    98
    Required:
    Porsche 993TT Calipers
    Genuine Pegs (ideally 18's for ease or 17's with 3mm spacers)
    S60R front discs
    Porsche OEM pads
    Brackets
    Brackets from CJ on SwedeSpeed or IPD
    Nope they wont
    Yeah, Douglas Valley Breakers is one
    Linky
    Member
    -CHRIS-'s Avatar
    Jul 2008
    6
    just having a look at the cars at that breakers... are there seriously any parts worth saving on this!
    http://www.douglasvalley.co.uk/item....&spg=68&pgid=2
    and check out the tvr's too!! how many with engine/dash fires? thats just scary!
    aeroresh's Avatar
    Aug 2005
    Mold, North Wales
    29
    apparently you need 20mm spacers for the big reds to fit behind a set of Volans!!
    '96 855 T5 auto ...GT30 and everything uprated!
  5. #5
    RT MECHANICS's Avatar
    Mar 2005
    Hampshire
    137
    Quote Originally Posted by Saaamon View Post
    My question are:
    Cheers..
    Saaamon
    Hi Saaamon
    Save your money up and buy AP's they are the best choice
    Russ
    LOOK at our project :
    http://www.vpcuk.org/forums/showthread.php?t=16301
    591 BHP 524 Ftlbs torque so far
    The Most Powerful T5 in the UK
  6. #6
    walter leever's Avatar
    Nov 2008
    lommel,belgium
    40
    Quote Originally Posted by RT MECHANICS View Post
    Hi Saaamon
    Russ
    true,but very expensive to replace discs etc,but one of the best systems around.(there's also MOVE-IT,and genuine volvo bbk,but the last one is sold out.)
    Myself i'm also going for the S60R discs&porsche callipers.
    get in,shut-up and hold on.
  7. #7
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Hi Saaamon
    Russ
    I would really like a set of AP's just because of the quality etc but with the prices quoted on parts for volvo at £1400ish :0 i've got a lot of saving haha...
    Saaamon
  8. #8
    Nov 2008
    lommel,belgium
    40
    Saaamon,ET do 3 different bbk kits:
    1-330mm brembo's,textar brake pads,braided hose lines and a 4-piston
    Porsche calliper and adaptors,1495euros(this is the set i'm getting)
    2-Ctf set 2 piece brake discs(aluminum center,lower weight)330 mm,Mevius
    racing brake pads,rest as above,1998euros.
    3-and their own (European Tuning)2 piece brake discs(aluminum center),
    6-piston brake callipers,rest as above,1750euros.
    these are the reasonable priced options.
    walter
  9. #9
    Mar 2005
    Hampshire
    137
    Quote Originally Posted by walter leever View Post
    Hi Walter
    The best usually are expensive you could try stoptech as well have you tried a car with the porsche set up ? and a car with AP's ?
    Russ
  10. #10
    Alan M's Avatar
    Jul 2008
    Midlands
    46
    Hi Spec will make a caliper/disc setup if asked. Has anyone tried them for a price.
  11. #11
    Nov 2008
    lommel,belgium
    40
    Hi Walter
    Russ
    i know russ,but i'm not a miilionaire.
    as for the porsche set-up ask me again in a few months.
    as for the AP set-up there are a few on the dutch volvo forum with those
    aswell as the other brands,probably millionares.
  12. #12
    Nov 2006
    Cambridge
    21
    Hiya,
    in my experience it would need to be at least 16mm spacers to fit 993TT calipers under Volans. I had 15mm ones and they wouldn't quite clear.
    For my 17" Pegasus I'm running 3mm spacers. I have heard there are two manufacturing plants for the wheels, Germany and Poland. My genuine Pegasus were Polish made, and shaved a sliver of paint off the caliper. There is a theory that this is a tolerance/quality issue and the German wheels don't touch. I haven't tried a German Pegasus so I don't know.
    That's not the only reason I went to a 3mm spacer though - the other reason you should consider it (for 17" OR 18") is to put the scrub radius back to the value it would have been with stock (for an 850R) Volan wheels on a 43mm offset. This can affect handling and I swear I felt more tramlining and torque steer effects going from a 43mm offset 7J Volan to 46mm offset 8J Pegasus until I put the 3mm spacer on.
    HTH, Pete
    '97MY black 855R manual M56H
    Porsche/S60R BBK, 17"x8J Pegasus, RIP, Samco coolant & vac, Koni SSK/Nivo, Simota, 15G angle flange, IPD turbo back & HT, MSD coil, chipped, dimming mirror, Goodridge hoses, DOT5.1, V70 rear lights & handles, poly top bush & A arms & tie bar, strut brace, clear repeaters, 6k HID, catch tank, 2x rear brace
  13. The Following 2 Users Say Thank You to dooby For This Useful Post:
    Flatout Phil (Monday 7th September 2009),siamblue (Friday 30th January 2009)
  14. #13
    Mar 2005
    Hampshire
    137
    Hi Walter
    I am no millionaire either
    Russ
  15. The Following User Says Thank You to RT MECHANICS For This Useful Post:
    volvolised (Friday 30th January 2009)
  16. #14
    Jul 2005
    35
    O.k ...I think the 993 tt's are excellent, am running them with ds2500's and work great but squeal like ££££.....have been in tims car on a white knuckle ride and believe me those ap's are brilliant and fill you with confidence....the 993tt's aren't quite as good but when set up correctly with brake fluid and decent rear pads and discs are well worth a good £1K saving....I'm running mine with 18" kahn rs-s which are 8j and 35 offset so no spacers ....the car is Very well planted on this set up ...the porkers look the biz too..
  17. The Following User Says Thank You to volvolised For This Useful Post:
    Enigma666 (Sunday 1st February 2009)
