So now you have a “tweaked” turbocharger – what are the advantages and disadvantages?
The “base line” boost of the turbocharger has been increased to 6 psi – meaning that the impeller blades are allowed to “idle” faster than before on part throttle opening. This means that boost is available sooner when the throttle is opened wide - hence it has the effect of reducing turbo “lag”. However, as the baseline boost is now higher and the turbocharger can build boost much more quickly than before, it can also spike more easily before the ECU has time to make corrections.
So the delay introduced by leaving the ECU in line means that it is now much easier for a boost “spike” to exceed safe parameters and the ECU may react by cutting off the fuel to the engine. Secondly, the ECU is still measuring the output of the Mass Air Flow sensor. It will react to the higher volume of air entering the engine by reducing the boost pressure via the wastegate solenoid valve. The onset of “knock” will cause the ECU to retard the ignition and also to back off the boost level. Luckily it does take a finite time to do so - therefore there is an increase in boost but only for a short time, until the ECU returns it to what it considers to be “normal”. [This isn’t as bad as it sounds – carefully study this extract from one review on the T5R.
“The R's engine management system has been programmed to allow the turbocharger to kick boost from 9.6 psi to 10.9 psi in 7-second bursts during maximum acceleration. This ups the horsepower rating to 240”.
