Results 1 to 12 of 12
    mikouk's Avatar
    Jul 2008
    New Forest, Hampshire
    212
    Water loss confusion!
    My dads losing water from his car. He keeps filling it up but its still going through a tank a week. He's had it pressure tested with no results and theres no water inside the car so its not the heater matrix.
    Any ideas guys and girls? its a 2001 P2 V70 T5 by the way.
    Also he has a rattle behind the passenger side vent. Any ideas?
    Cheers
    Mark
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
    Loadsamiles's Avatar
    Jul 2008
    217
    Quote Originally Posted by mikouk View Post
    Cheers
    Mark
    Yeah it's probably a split hose.
    Mine was doing it 2 weeks ago.
    It was loosing water at the strangest times and not others.
    The split was next to a jubilee clip and only the size of a pin. when the temp got up to operating temps it started spraying out, but it did still hold pressure in the expansion tank.
    Check all hoses near their clips.
    I fixed mine with a pair of scissors. I just cut 25mm off the end and re-terminated the hose.
  3. The Following User Says Thank You to Loadsamiles For This Useful Post:
    mikouk (Wednesday 21st January 2009)
  4. #3
    Jul 2008
    Red Lodge
    11
    also check the cap itself.....
    water can also be lost as the car cools down if a jubilee clip is not tight enough as the diferent parts expand/contract diferently
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=2552&dateline=1218822  313
    She may not be perfect but i love her anyway....
  5. The Following User Says Thank You to PNuT For This Useful Post:
  6. #4
    mikouk's Avatar
    Jul 2008
    212
    Thanks guys, but would those problems have not shown themselves during the pressure test?
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
  7. #5
    May 2005
    Chester, UK
    98
    Not likely, unless they pressure tested the system beyond its normal operating pressures. Even then it's all about hose expansion rather than the pressure being put through the system.
    Check it over night...measure it last thing at night then again in the morning and see what the outcome is, that will give you more idea of the issue at least
  8. The Following User Says Thank You to Enigma666 For This Useful Post:
  9. #6
    Baj's Avatar
    Mar 2006
    Woking
    11
    I had a leak on the inside of a 90deg bend in a hose. Was a bugger to find. A tiny hole and only leaked once the pipe warmed up.
    Get it up to temp and give all the pipes a good wiggle. Watch for boiling water in the face
    It should really be leaving obvious puddles somewhere.
  10. The Following User Says Thank You to Baj For This Useful Post:
  11. #7
    Old Fart
    Porcine_Aviator's Avatar
    Jul 2008
    Weston on the Mud Somerset or in it if you get the tide wrong.
    699
    I had a small leak next to the top hose, only showed up when the car was hot. Had the thing checked but it didn't show up until someone opened the bonnet when she was really hot and noticed a small drip of water.
    Fixed with the help of a screwdriver.
  12. The Following User Says Thank You to Porcine_Aviator For This Useful Post:
  13. #8
    Singing in the rain!
    CONDYBOY's Avatar
    Jul 2008
    North East England
    36
    Go-on be a devil, put some washing up liquid in the cooling system and start the engine, let it come up to normal temp and look for the bubbles.
    "I am never wrong! Just in a position to learn something new!"
    Mods so far, HLM ReMap, Goodridge brake lines, Eibach springs lowering 35mm, K&N57i filter with cold air, Strut brace, Shark fin aerial, Boost guage
    YES IT'S A DIESEL
    Wish list, BOV, 18" rims, Struts, Stainless exhaust, Injector Upgrade, MORE POWER!
  14. The Following User Says Thank You to CONDYBOY For This Useful Post:
    mikouk (Thursday 22nd January 2009)
  15. #9
    Jul 2008
    Bristol, UK
    32
    Water loss in my (limited) experience is due to any of the following, in order of cost:
    1. Poor attachment of a water hose clip
    2. Split hoses (coolant-coloured puddles)
    3. Leaking radiator caps (it boils away slowly - you may see steam)
    4. Leaking radiator (look for crystals of coolant on it)
    5. Failing water pump (some leak to say they're on the way out, don't know if Volvo's pumps do this)
    6. Head gasket (see if the engine temp is running very high and/or there is mayonnaise on the oil filler or radiator cap)
    1, 2 and 4 can be temporarily repaired with something like RadWeld, which is often a controversial recommendation!
  16. The Following User Says Thank You to daveforber For This Useful Post:
  17. #10
    Junior Member
    cez97t5's Avatar
    Jan 2009
    Istanbul Turkey
    0
    HI
    Please check the contimination in engine and transmission oil
    Check in night time with hand light for a steam from any hose connections and from radiator caps when engine in a normal temperature and running in idle mod or time to time force engine to 3000-4000 rpm
    İf you using OAT (organic acid technology) antifreeze red or orange color the location of the lost area of cooland need to be have film at the same color at cooland color
    good luck
    Of the short time ago I be have the same problem and find them from the radiator caps in steam faze in night from car light and use chemichal treatment for fix radiator leaks, but not use all treatment because have risk to pluging radiator tube, need to be careful when using the same treatment.
  18. The Following User Says Thank You to cez97t5 For This Useful Post:
  19. #11
    01c70t5
    Guest
    common problem is the expansion cap failing... check it for signs of hot coolant leaking, or run it up to temp and check for a leak.
    if not, it's a pipe and a bugger to find!
  20. The Following User Says Thank You to 01c70t5 For This Useful Post:
  21. #12
    mikouk's Avatar
    Jul 2008
    212
    Is that ok to do that?!!!!
    V70 T5 P2 2001
    RICA UPGRADE
    KONI FSD SHOCKS
    EIBACH SPRINGS
    POLY TOP MOUNT
    18" NEBULA'S
