Hi all ive seen some of the cars with the bonnet raised at the windscreen end and in previous post it was a recommended mod to do so how do i go about adjusting it to sit higher at the wind screen end cheers all
I never heard of this one b4 lol would the car not look a bit stuppid by doing this?
Martyn
It makes the bonnet look quiet aggressive here's the link there's a pic about half way down the page with the raised bonnet
http://www.vpcuk.org/forums/showthre...t=17613&page=2
That’s not my cup of tea, I think if you track raced your car all the time it may have some effect (minimal I would have thought) but for normal road driving is there any point?
Martyn
True it would be different lol and you will probably get flashed allot from oncoming drivers cuz they think you have left you bonnet open
Martyn
I think, if memory serves me (less frequent these days) Pedro did something like this, although i believe (correct me Pedro) that he cut away the bonnet seal and plastic at the screen end of the bonnet instead of raising. Worth a PM i would say
Unless you were in a traffic jam on an august bank holiday (or at a track/drag meet) -The ambient temp under the bonnet will only affect the engine performance if you choose to have hot air induction as shown by the picture above.
Basically pedro - gawd bless him - has created an engineering problem by sticking an unsheilded air intake next to the block.
- hot air rises - its less dense than cold air - sadly that cannot be said of some owners.altho you couldn't feel any difference when stopped in traffic you could see the heat haze coming from the gap so it was doing something
Not as much as stress - reading this drivel.Just to be different the cooler the engine bay the less stress on the engine components and proberley with the engine been slightly cooler and the hot air escaping quicker a slight mpg gain but wouldn't be much
I admit heat soak is a problem - but only in extreme conditions. As for gaining horse power through "having a gap" - I think opening a gap on the drivers window to let this particular hot air out would be a better bet.
Volvo ABS ECU Repair
oh Dave mate the pic is an old one & was posted to show the scuttle panel which is what the topic was about (yes its changed & it is still an open cone). Both being old-timers you should know i've never been one to work by the book. I know the theory "hot air bad, cold air good". Over the years i've gone thru many (& many) different intake designs both sealed & open, & for some reason an open cone design has ran faster 1/4mile times.
I know you've always said the standard airbox is good enough but i can't see it, the pipes are small, the MAF screen does nothing but block air, the corrugated section disturbs the air & their are too many bends. The standard intake position is next to the radiator which also gives off heat if i'm correct?
I may only be the stupid son of physics teacher - but as far as I know there are only 3 ways heat energy can 'move about' - for want of a better phrase
Conduction
Radiation
and
Convection.
Are you now contending that the position of the plastic tube into the standard airbox - is a poor design, due to conducted heat from the radiator?? It can't be convected (its a closed system) - radiation is equally unlikely and conduction (plastic is not a good conductor of heat).
The air passes through the water and convects away the heat from the hot water in the rad. First thing that air hits, after the rad pack is the engine block. So by unenclosing your air filter - at best all you can hope for is warm air??
I have seen the video on IPDs web site about the Short Air Ram. There may be some merit is smoothing the laminar flow of air into the turbo but again we are fighting over tenths of HP if that??
Look at the air intake for the BTCC car!! High EGT are the enemy of forced induction - so surely raising it by inducting air warmed by both the radiator and the block is just DAFT
My other comment was tongue in cheek - but I still think this skuttle panel removal smarts of desperation
i'm the son of a HGV driver, give me 100foot of truck with 14gears doesn't mean i'll be able to drive it
as you said in your first post "sat in a traffic jam on an august bank holiday (or at a track/drag meet)" the standard air box would still suffer from a degree of heat soak from the radiated hot air from the radiator because of the opening being there (not forgetting the other faults/flaws i mentioned in the standard airbox design)Are you now contending that the position of the plastic tube into the standard airbox - is a poor design, due to conducted heat from the radiator?? It can't be convected (its a closed system) - radiation is equally unlikely and conduction (plastic is not a good conductor of heat).
we all know the theory side & hot air isn't as good, i was also told you'll lose power by fitting a decat & that was wrong. Whether the hot air intake isn't sucking in as much hot air as being tried to make out, or the straighter pipes counteract heat loses i don't know. But instead of just going by the book or ignoring an idea becuase someone says "it won't work becuase" i've tried it, & an open cone has given me a quicker 1/4mile time & i like it how it is so i'm sticking with it (until i try something else lol)I have seen the video on IPDs web site about the Short Air Ram. There may be some merit is smoothing the laminar flow of air into the turbo but again we are fighting over tenths of HP if that??
But sat in a traffic jam - you are not going anywhere and how many times a day do you find yourself on a track day or drag strip?
So my point still stands and your arguement about the downpipe adds no more credulity to the hot air induction/unshielded cone.
I'd happily stick my car on a dyno with and without shielding to prove the point.
i'm lost, wasn't that what i quoted you as saying. Have you just questioned yourself there? (HELP ME I@M CONFUSED)
the downpipe was used as an example of "don't take everything written as gospel", as i said i've tried many different intakes & the open cone (so far) has proved to be better on my car, as i'm using 1/4mile times for my judgement 9 times out of 10 the engine bay would of been nice & warm after sitting in the warm-up lane waiting to stageSo my point still stands and your arguement about the downpipe adds no more credulity to the hot air induction/unshielded cone.
i'd be pretty impressed if you can do 2 runs with a car in the same spec that runs consistant to several bhp of each run, let alone being that accurate to record a reliable bhp difference between filters (but lets not go down the rolling road argument)I'd happily stick my car on a dyno with and without shielding to prove the point.
What I meant was - the only time heat soak occurs is in extraordinary circumstances. In a traffic jam - you can't move anyway and second the track day/drag strip, is so seldom to make it a null point.
At the end of the day the original question - letting the hot air out - has so little influence on the outcome when compared to that of hot air induction/higher EGTs that I believe it is an excercise in futility to remove the scuttle or jack up the hinges.
You'd be far better of sorting out the induction with proper sheilding or sticking with the stock box?
i did actually say in my first post in this thread "i didn't notice any difference by removing the seal"
as for sticking with the stock airbox, we'll have to disagree on that one because i feel like i'm going round in circles. We all know the theory, i know what i've triedYou'd be far better of sorting out the induction with proper sheilding or sticking with the stock box?
However - I think the net result of the arguement for this thread remains the same. There is no point to elevating the rear edge of the bonnet. Can we agree on that?
My final clarification on the stock air box would be I meant to include the words "with a performance panel filter"
Unshielded cones filters can only be worse than the stock + filter for points I have previously eluded to, namely hot air intake.
...and indeed you may yet still disagree.
