i want to put V70 rear lights on the rear of my car as some people have done.
is it just the top half that people change
is it just the outer coloured lens i change or do i need the bulb holder bit to?
hi, I changed mine to v70's, just the top half, the bulb holder in my 850 were slightly different from the V70 ones, so,if you can get the upper V70 lights get the bulb holders too.
before.....
After....
and......be careful with the nuts that hold the lights in they have a nasty habbit of running away! lol
the only problem you risk running with just buying the top sections is the difference in colour one set might be a little more faded than your bottom ones the best thing to do is buy the full set
IIRC they are held on by 3 x 10mm nuts
They have to be long reach as well
I changed the rears on pault5estates, easy job, just be careful you dont drop the bolts.
A magnetic t bar with a socket end would be ideal
Cheers
Lee
I had a crack on one of mine, and have changed all 4 just incase there is a diffrence in colour
Martyn
someone's probably lacquered them in the past and it's now peeling.. a good tip for anyone with dull lenses is to polish them up with Autosol (metal polish) and a machine polisher/drill with buffing wheel/dremel etc.. comes up a treat..
EDIT: I found a video of someone using this method! lol!:
http://www.metacafe.com/watch/151155...utosol_polish/
HTH .
1998 BMW Z3 2.8 Roadster
I wouldn't bother replacing the bottom ones unless they've gone 'Fogy', I've never seen a difference in colour on rear lights before. When I did mine I just changed the top ones.
Previous cars:
very true also with age meterials do get tarnished/faded/dull etc so when fitting something newer there is a chance of the apperance being different yours may not look dull but remember you see your cars lights all the time its only till you put a newer set besides it and then you can see the difference dont get me wrong yours could well be in very good condition and will match up to a newer set but imho i would rather get a full set which i did before fitting the ones i have on now
volvokid (Saturday 3rd January 2009)
I notice you have the exact same 6x9 in the floor of your boot as i had in my old V40 i put them in my boot almost the same as that and found they sounded horible the bass sounded messed up. i just left them there as i didnt want to replace the whole floor. how does yours sound?
Martyn
Mine may have sounded crap due to the difrence in material were you have yours is all wood but in the v40 it wasnt.
Martyn
