Previous cars:
Or a more detailed.....
Reverse piping
Normal piping
LesRED850R (Monday 12th January 2009),stainesy (Friday 2nd January 2009)
Yeah, thanks thats a great help
Well strictly speaking the reverse piping was the original, but volvo changed it supposedly because in colder/icy weather (in sweden and other cold countries) the cooler air coming from the bottom of the intercooler caused the throttle body/flap to freeze up/ice up. So they swapped the pipes around so that the slightly warmer air from the top of the intercooler went to the TB thus solving the problem.
But since it doesn't get anywhere near as cold in this country (or not often anyway) the reverse IC setup is fine.
You can get them from www.europeantuning.com
they cost 379 euros,that's where i got mine(ipd version)
to make your own, you need.
? = whatever size pipe you want to use
top turbo to IC top pipe
1 x straight reducer (turbo top - ?)
1 x 90degree (? - ?)
1 x 45degree (? - ?)
1 x 45degree reducer (? - IC top)
bottom IC to throttle body pipe
1 x 90degree reducer (bottom IC - ?)
1 x 90degree reducer (? - throttle body)
will need a 19mm T-piece to connect the idle control valve
turbo inlet pipe
1 x 90degree reducer (turbo inlet - ?)
will need a 9mm T-piece to connect the PCV (inless running a catch tank) & you'll also need a 40mm collar welding in to fit the MAF sensor
you'll also need about 3metres of pipe & 18 jubilee clips
PaulZX (Sunday 11th January 2009)
nice1 mate. i will be using a catch tank. at the mo mine is venting to atmos as it has broken under the manifold so its leaking crap onto the bottom intercooler pipe. but its still fine to drive and i have blocked the hole in the air pipe to the turbo so i will sort that when i get a chance in a few weeeks. should be ok till then
I'm going to order the RIP kit from IPD, Just have to wait for them to get the new style in stock.
Martyn
is it really that simple?what about the silicone hoses,are they simply bends or do i need to get special bends made up?
945 - being fettled
nissan cube -
ish, you will need several pieces welding (T-piece for the idle valve, PCV & MAF collar)
nope all brought off the shelf, even all the angled reducers were brought straight off ebay (seller called nicenewcar)what about the silicone hoses,are they simply bends or do i need to get special bends made up?
Is there really any noticeable benefit for doing this?.. seems like a lot of hassle (and expense) if there's not.. I've read a few posts on it and am still unclear as some people say it makes a difference and others don't... hmmm..
1998 BMW Z3 2.8 Roadster
i am so going to this when i get time!
red 96 850 t5 rica304 K&N cone filter Bailey dump valve
ferrita 2.5 in cat back
"A volvo isn't made for tupperware parties"
When i fitted myne the pick up was a bit quicker but nothing much i think the main reason ppl fit this is due to how nice the pipes look
Previous cars:
