I have a 98 S70R with 100k,the air con has suddenly started turning itself off every 8 seconds,it stays off for about 4 seconds then turns itself on again,it still blows cold air,any ideas
Bert
Bert
Yes this is known in the trade as short cycling! most probable cause is the shaft seal around the compressor leaks over the winter months- when not in use and leaks refrigerant. Take it to your local air conditioning company & get them to have a look. If it req's re-charging cost is around £30- £50!
Thanks for that,will the refridgerant company have the seal or would i have to get it from volvo,
Regards
Discuss with them mate, but they should be able to sort it all out for you. What are do you live in? If it's near Nottinghamshire I can suggest a few good companies!
Ireland, a little bit out of the way
Hey camo, I'd be interested in hearing about good a/c companies in the mansfield area, my missus' S40 needs looking at in the coolness dept.
David Pengelly in Lenton now has all the gear to do aircon, and he knows his Volvos inside out!
2004 V50 T5 SE
Just wondering my a/c doesn`t work anymore due to not being used for months, could it be a similar problem? The a/c button lights up but there is no drop in engine revs or noise of it turning on.
Sounds most likely, it's always the first choice to get it checked and re-gassed, a lot of people don't realise the workings of air-con and the winter, it always keeps things going if you use it a few times a month ALL year... sometimes you lucky and the seals don't dry out... but most will with little or no use....
Once you start using it again they should return to doing thier job and stop the gas getting out...
Get it checked, and see where it leads...
