Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 121
Thread: Catch tank
  1. #21
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    Quote Originally Posted by BruceT View Post
    Which ones you looking at Stainsy?
    i was looking at this one mate
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370072335486
    so basicly i get a catch tank, put the pipe from the air pipe to it,
    another pipe coming from the tank going out under the car.
    what do i do with the tiny hard plastic pipe going to the air pipe?
  2. #22
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    could you run the pipe to the catch tank then a pipe from the tank to the air intet where it is originally stiuated to stop the oiley smells or would it be better to get the catch tank in the pic also i think there is two pipes leading to the air inlet pipe isnt there do they both come from the pcv
    http://cgi.ebay.co.uk/ALUMINIUM-OIL-...1%7C240%3A1318
  3. #23
    dangerstevie's Avatar
    Nov 2008
    Stoke on Trent
    2
    The whole idea behind the catch tank is not to plumb it back into the intake as the oil vapors lower the effective octane of the fuel. Better to run from the crankcase to the catch can, then from to catch can to atmosphere via a small breather filter if you want to minimise the oil smell, or you can just run the outlet pipe under the car and ignore the oil smell.
    Low cost auto diagnostics, prestige car specialists, mobile service in Staffordshire.
    www.mobilediagnosticservices.co.uk
  4. #24
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by t5 pete View Post
    i think you'll find on yours the little pipe comes from the inlet manifold, mine was plumbed different & had that pipe going to the vac tree, then another going to the air inlet). I've just removed it, but as i say mine was different anyway
  5. #25
    stainesy's Avatar
    Jul 2008
    dunstable
    10
    on mine i have the big pipe then a smaller one coming from the vac tree that sucks air. and i tiny white plastic pipe. the vac pipe on mine is constantly hissing as i can not get a good seal on it no matter what i do and the big pipe is constanly pulling the hole rubber bung out of the air pipe as its at a stupid angle.
  6. #26
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by p fandango View Post
    Now you said that i do remember it does come from the inlet manifold i geuss i should just leave it where it is also did you blank the opening off where the pipe originally went
  7. #27
    Suspended
    Oct 2008
    seaside
    32
    Great info guys, didn't realise the stock system compromises all that lovely v-power fuel i use, lol! sounds a well worth while investment.
  8. #28
    p fandango's Avatar
    Aug 2004
    4,216
    i made up a new larger intake pipe while i was doing the larger reverse flow so haven't got any openings. You don't want air escaping from anywhere, you should block all pipes off you remove
    top pipe is the intake, the collar is for the MAF sensor. The bottom pipe is the reverse flow pipe from the bottom of the intercooler to the throttle body (for those interested)
  9. #29
    Nov 2008
    Stoke on Trent
    2
    If one of your vac pipes is hissing stainsey i wouldnt drive it till i got that sealed, it will be causing the motor to run lean by letting in unmetered air.
    One other question. The oil separation tank under the inlet manifold, can this be removed when the catch can is fitted.... i would have thought you could remove it, but is it recommended?
  10. #30
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Ive just had a brain storm i mite be wrong tho but is the tank better being fitted the same level as the pcv or lower due to all the **** having to travel upwards if the taank is higher if the tank is lower than the pcv wouldnt its make it easier to flow
  11. #31
    Nov 2008
    Stoke on Trent
    2
    That is a very ver nice setup you have there, my mind is made up on what i am going to do. i just want all the silicone black and all the pipes powder coated black to match. its a bitch of a job to keep everything shiny.
  12. #32
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by dangerstevie View Post
    not that i know of, it has other pipes venting to it so think its best to keep it in place
  13. #33
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    That is one hell of a set up you have done, how did you manage to secure the MAF sensor into the round opening or did you use long screws that screws into the main piping i am really considering making one now the only thing that would put me off its the open filter do you think it makes any difference from a closed filter
    cheers pete
  14. #34
    BruceT's Avatar
    Jul 2008
    Bristol
    218
    P Fandango, your pics are not working for me.
    I think who ever does should take pics so we can all follow and give constructive critism with pictures so we all know/see what each other mean.
  15. #35
    Nov 2008
    Stoke on Trent
    2
    Keep the filter sealed from the engine bay hot air. It WILL be making a difference. Although a decent cone filter that flows enough for the motor at peak boost and RPM when sealed from the hot air in the engine bay will out perform the panel filter, it may shift the torque up the RPM range slightly making the car feel more sluggish low down.
  16. #36
    Nov 2008
    Stoke on Trent
    2
    Ill be gettin my catch can from my mums over xmas so i can do a how to shortly after, and i also have to do my RIP setup so i can do that one too. but that will be as funds allow after xmas.
  17. The Following User Says Thank You to dangerstevie For This Useful Post:
    t5 pete (Sunday 21st December 2008)
  18. #37
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    I dont under stand what you mean the top piping in the pic is for the air flow the bottom pipe just desgard it its for the i/c piping i think this pic is very good and help full and has also gave me other ideas on what to do
  19. #38
    BruceT's Avatar
    Jul 2008
    Bristol
    218
    Not working as in, it doesnt display a picture - just a link to some hosting website mate
  20. #39
    p fandango's Avatar
    Aug 2004
    4,216
    i was going to get an machine shop to make a flange the same as the MAF that could be welded onto the (40mm diameter) collar, in the end i just siliconed the sensor in
    cheers pete
    i've never noticed any difference between open or sealed
  21. The Following User Says Thank You to p fandango For This Useful Post:
  22. #40
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    OHHHHHHHHH i get what you mean it seem to be working for every one else i havent got a clue why it isnt for you
